Calling Excel experts....
Been thanked: 1611 times
I've got a sheet where I want to compare 2 units of data and then pick whichever hits its target first - one being an hours run figure and the the other being days elapsed (say 40000 hrs and 1000 days).
What formula should I use? I used be be pretty good an Excel but it must be 10 years since I've used it seriously!
Has thanked: 781 times
Been thanked: 1072 times
Re: Calling Excel experts....
I'm not sure I follow, do you have 2 columns of readings and you want to find the smallest in each or do you want to combine date & hours to find the first overall?
Mussels wrote: Mon Mar 07, 2022 3:21 pm I'm not sure I follow, do you have 2 columns of readings and you want to find the smallest in each or do you want to combine date & hours to find the first overall?
Sorry, my bad...
I've got 2 lots of data - operational days and running hours, and a formula running to bring both to a position where can be compared. The formula I now need is to compare both sets of data and to select whatever comes soonest - I'm currently using the IF command but seems a little flakey.
=ROUND(IF(TODAY()+E4<(TODAY()+(F4/$G$2)),TODAY()+E4),0) Where E4 is the operational days and (F4/$G$2) is taking hours run (F4) and dividing by average hours per day ($G$2) and giving a a part-day figure.
Cheers
I'm not sure about the F4/$G$2 part but to show the smaller result of the two something like this should work.
=IF(E4>(F4/$G$2),F4/$G$2,E4)
Mussels wrote: Mon Mar 07, 2022 6:34 pm I'm not sure about the F4/$G$2 part but to show the smaller result of the two something like this should work.
Cheers, I'll give that a try tomorrow.
Kneerly Down
Has thanked: 135 times
Been thanked: 254 times
Post by Kneerly Down »
Easier to just use =MIN(E4,F4/$G$2)
