Yes.
it was a Honda Jazz
You need to start painting your victories on the tank.
Did the bike retain all components?
I've stopped even asking that. All I worry about now is whether the part which fell off is important.slowsider wrote: Wed Jun 29, 2022 7:42 amDid the bike retain all components?
I expect you will eventually start doing preventative maintenance.Mr. Dazzle wrote: Sat Jul 02, 2022 5:03 pm Turns out one of the two centre stand bolts had escaped. I hadn't noticed cause I put it on the sidestand in the garage. When I went to lift it onto the centrestand today, unaware it was only half on, I bent it instead. FFS. I'm down to one stand now, I reckon I'll start parking near walls just incase that one escapes too.
Potentially true...dunno what I can do about it though really, other than seek out "classic" plugs, if such a thing even exists. If I eventually land on a plug after trial and error it should be OK right?ogri wrote: Sat Jul 02, 2022 6:10 pm Sure i read somewhere that modern ngk plugs are not very good for older bikes as they are made different to allow for the technology on modern bikes?
They’re fine in my 1955 bike.ogri wrote: Sat Jul 02, 2022 6:10 pm Sure i read somewhere that modern ngk plugs are not very good for older bikes as they are made different to allow for the technology on modern bikes?
If you go much over 10 kOhm total, you may lose sparks (or maybe not).Mr. Dazzle wrote: Sat Jul 02, 2022 6:16 pmPotentially true...dunno what I can do about it though really, other than seek out "classic" plugs, if such a thing even exists. If I eventually land on a plug after trial and error it should be OK right?ogri wrote: Sat Jul 02, 2022 6:10 pm Sure i read somewhere that modern ngk plugs are not very good for older bikes as they are made different to allow for the technology on modern bikes?
Maybe you're thinking of more modern resistor plugs, normally they have an R in the number. Somewhat moot though cause I've fitted 5 kOhm resistor caps! Modern bikes need resistor plugs so the electrical noise from the ignition doesn't interfere with the ECU, but there's no real harm in fitting modern plugs to "analogue" engines.
It does have older style copper core HT leads though, whereas modern vehciles sometimes have the silicone/carbon ones. Or more often than not these days no HT leads at all.
Ok, to look at it another way, the bike in your hands appears to have been thrown together and neglected. You have little reason to have confidence in any of the assembly.Mr. Dazzle wrote: Sat Jul 02, 2022 5:35 pm Gotta be honest, I don't consider checking the stands are still bolted on to be preventative maintenance![]()
I rode the Mirth like that for months, it's fine.Mr. Dazzle wrote: Sat Jul 02, 2022 5:03 pm I reckon I'll start parking near walls just incase that one escapes too.
I imagine my problem is that I've fixed stuff!JackyJoll wrote: Sat Jul 02, 2022 7:56 pmOk, to look at it another way, the bike in your hands appears to have been thrown together and neglected. You have little reason to have confidence in any of the assembly.Mr. Dazzle wrote: Sat Jul 02, 2022 5:35 pm Gotta be honest, I don't consider checking the stands are still bolted on to be preventative maintenance![]()
