Technology used by only a small number of manufacturers
Been thanked: 2721 times
Is there something that only one manufacturer has used? There's a few that come to mind:
Honda and their oval pistons. I suspect this is the only one off, but it's a shape thing more than anything.
Ducati and desmodromic valves.
Sunbeam and the worm drive on the S7 and S8.
Buell and the rim mounted caliper.
Any others, there must be more?
Re: Technology used by only a small number of manufacturers
Combined kickstart and gear levers, beloved of the East Europeans.
Dynastarters, a dynamo that also functioned as an electric start. If you were lucky from what I've read.
Been thanked: 9454 times
BMW, three button indicators :(
Been thanked: 4527 times
cheb wrote: Wed Mar 31, 2021 11:25 am Dynastarters, a dynamo that also functioned as an electric start. If you were lucky from what I've read.
They worked on the bikes I had with them, Suzuki GT185 and GT200X5, and seemed to work on my mates RD200, bloody pointless and heavy though.
I'll add my tuppence worth - oil cooled engines, only Suzuki did this, though in reality it's an air cooled engine with a massive oil cooler and very high oil flow.
I believe Mercedes did Desmo cars a long long time ago.
Yamaha 5v heads? Pretty common in VWs and a few Ferraris, but no other bikes?
BMW do/did (partly) oil cooled engines.
cheb wrote: Wed Mar 31, 2021 11:23 am Is there something that only one manufacturer has used? There's a few that come to mind:
The last two sound like the dullest children's books ever.
Has thanked: 1924 times
Been thanked: 1728 times
buell and a pull mounted rear shock ( it didn't work well)
Buell and full in the frame - didn't work well as if the bike fell over ( as they were prone on walking when on the side stand when switched on) it wrote the bike off ...
Mr. Dazzle wrote: Wed Mar 31, 2021 11:33 am I believe Mercedes did Desmo cars a long long time ago.
That's just the number of valves though, same as the Honda piston shape.
Any bikes with sleeve valves or rotary cone valves?*
Opposed pistons but no cylinder heads?
*Yes: http://www.douglas-self.com/MUSEUM/POWE ... alveIC.htm
I may be some time in here: http://www.douglas-self.com/MUSEUM/museum.htm
Aprillia used 5V engines made by Rotax
Mr Moofo wrote: Wed Mar 31, 2021 11:38 am buell and a pull mounted rear shock ( it didn't work well)
If you're talking shocks...Suzuki rotary dampers?
Nidge
Has thanked: 684 times
Been thanked: 673 times
Post by Nidge »
I still only associate EXUP with Yamaha - do any other manufacturers have something similar?
Has thanked: 7585 times
Been thanked: 5913 times
KungFooBob wrote: Wed Mar 31, 2021 11:28 am BMW, three button indicators :(
IIRC, Harley had two button indicators at one time, possibly needing to be held 'on'?
Ditchfinder
Has thanked: 859 times
Been thanked: 1067 times
Post by Ditchfinder »
Le_Fromage_Grande wrote: Wed Mar 31, 2021 11:33 am
There's a bloody big oil cooler on the side of my Griso too
The ZZR1100 C1 was the first production motorcycle with ram air induction.
Kawasaki H2 first proddy bike with a supercharger.
Nidge wrote: Wed Mar 31, 2021 12:34 pm I still only associate EXUP with Yamaha - do any other manufacturers have something similar?
Early noughties Fireblades have HTEV which is the same sort of thing. Doesn't roll of the tongue in quite the same way though.
Huh tev?
Hoooohtv?
Loads of bikes have exhaust valves. First that springs to mind is the Multistrada.
Has thanked: 10932 times
Been thanked: 3977 times
Desmo valve gear was also used on (IIRC) German WW2 aircraft engines, I seem to remember the ME109 engine used them. (as well as mechanical fuel injection and high pressure water injection!)
Or - as Dazzle pointed out - pre-war Mercs.
BMW R259 engines (1100, 1150 series) are "oil-cooled". (but yes - it's high flow oil with air-cooling and oil radiators).
Horse wrote: Wed Mar 31, 2021 12:37 pm
On Harleys each button is an 'on/off' toggle, I think they have a timer as well.
Has thanked: 12556 times
GSXRs have a valve flap thingy in the downpipes.
