Afternoon All,
Hope you had a nice Easter break!
Quick update on the ZZR and its (Rather eventful) Shakedown runs so far....
If you have any spare pennies, please feel free to donate here - Even a quid would help and make all the embarrasment outlined below worthwhile
https://fundraise.cancerresearchuk.org/ ... lenge-2024
First off - a Couple more runs in the bag, I swapped out the LED Conversion for the original Halogen one and I think I am going to stick with the LED for now as the beam on the standard set up is pretty weak. I am going to be riding through the night and need good visibility, and I am also going to have some additional draw on the battery from a couple of USB ports and a tracker so the LED will do for now - I will maybe try and find a better set up before the event in terms of beam pattern however!
On my previous update, I mentioned that I lost the pedal on the rear brake and had to re-bleed the system..... This unfortunately came back to haunt me on the weekend!
The plan for Monday was to hit between 100-150 miles (Weather dependent) to give the bike a proper shakedown to identify any long distance running issues as it's only been relatively short hops so far.... And we identified one quite major issue only 14 miles into it. I was heading out towards Buckingham I noticed that the engine began to feel a little sluggish and wasn't pulling great at low revs (Particularly in higher gears) so I was having to change down more - Something I hadn't noticed before which rang some alarm bells. The engine was still running ok and feeling smooth so decided to press on and see how things went. I had put some fuel system cleaner in with the latest tank of fuel so I put it down to that.
That was all - No other symptoms, rattles, clatters or bangs.....
Pulled up at a (very busy) roundabout and waited to pull out. When the opportunity came I went to release the clutch and the bike wouldn't move - Stuck to the spot. Engine was still running fine but was locked at a standstill. I had no idea what was going on (I was in first, No brakes on, clutch ok..... But I'd lost the rear pedal again I noticed..... Foreshadowing). At this point I was waving traffic past me, feeling like a bit of a dickhead - But that was just the start of it!
Guy comes running across the road shouting 'Your on fire mate!!'
So I jump off the bike, and he was correct - Flames coming out of the rear brake, about half a metre or so high...These flames were not going to be patted out, so I stick the bike on the stand and me and this guy are running down the queue of traffic asking for water or a drink or any type from anyone and finally a lady gives us her sports bottle of water.... Bikes still on fire and gathering pace at this point with the flames now melting the rear left panel. Dousing the rear with water and we manage to get the fire out quickly and drag the bike (back wheel is locked solid) over to the path so the traffic could move again.
I was so embarrassed - And then it got worse when I heard the sirens in the distance.
Guy who helped me out headed for his car, and just as he pulled off a police motorcycle pulls up followed by a police car, then another police car..... And then a fire engine ~ Someone in the queue must have dialled 999..... So I'm there, with my shitty smouldering bike with 5 cops and three firemen all laughing at me whilst all I wanted is for the ground to open up and swallow me - I was mortified
A hundred apologies for wasting everyone's time (They were all fine and in good humour) and they were off to deal with some real emergencies and I went and hid at the fuel station whilst the AA Came to sweep me up.
Turns out the pistons in the rear caliper had seized, and were on all of the time, destroying the pads and discs - But as I was on the move it was impossible to tell the brakes were binding (But hindsight tells me I should have stopped when I noticed the engine was feeling sluggish as it was the rear brake pulling me back). As I was on the move also there was no noticeable burning or flames due to the cold air and no visible smoke - but once I stopped the pad plates (melted metal at this point) welded themselves to the disc and burst into flames along with all of the rubber seals and gators on the caliper.
Ugh
The AA Guy was also laughing at me a fair bit
These pads were only 50% Worn
Caliper looks to be salvageable, the brake line is ok so best case I need a new disc (found a second hand one on eBay for £15) and new pads, pistons and seals.
All being well I can get the parts this week and them get things back together and in working order over the weekend.
I knew there would be drama along the way with this challenge - But not fires!
