Resource Limit
What can the Admins do to help, any requests for changes, updates, etc.
Has thanked: 711 times
Been thanked: 2014 times
Re: Resource Limit
HiFi Kabin wrote: Tue Jan 07, 2025 10:07 am Not sure what you mean, can you give me a screenshot so I can see it
This arrow.
Been thanked: 9448 times
Re: Resource Limit
I don't think it does anything, just changes colour when you click it.
Re: Resource Limit
Ahh. Click it and it takes you to the original post. Must be a new feature
Re: Resource Limit
Felix wrote: Tue Jan 07, 2025 10:10 am Ahh. Click it and it takes you to the original post. Must be a new feature
That's been there forever,man. :D
Re: Resource Limit
Skub wrote: Tue Jan 07, 2025 10:12 am
Are you gaslighting me?
I ain't not never seen it before.
Re: Resource Limit
Naw its no. I only noticed it this morning.
Re: Resource Limit
KungFooBob wrote: Tue Jan 07, 2025 10:14 am
It used to be two little arrows together,but it did the same job. :thumbup:
Been thanked: 3207 times
Re: Resource Limit
KungFooBob wrote: Tue Jan 07, 2025 10:04 am What does the up arrow on quotes do when you click it and it goes red?
It usually jumps you up to the original posting of that quoted post
HiFi Kabin
Been thanked: 98 times
Re: Resource Limit
Post by HiFi Kabin »
Correct, I thought you meant the quite button not the quoted text, hence my confusion
Has thanked: 12553 times
Re: Resource Limit
If I try to quote or add pic I get big error message
Re: Resource Limit
I can't add the screen dump
HiFi Kabin
Re: Resource Limit
What style are you using?
If you are not using prosilver, please change to it and see if it works then
Re: Resource Limit
I have no idea what prosilver is
Re: Resource Limit
Looks like the SQL code has been fucked up or rogue data in the database
[phpBB Debug] PHP Warning: in file [ROOT]/ext/david63/privacypolicy/event/listener.php on line 351: Array to string conversion
[phpBB Debug] PHP Warning: in file [ROOT]/phpbb/db/driver/driver.php on line 750: foreach() argument must be of type array|object, string given
Return to the index page
General Error
SQL ERROR [ mysqli ]
You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ') WHERE b.display_on_posting = 1 AND b.bbcode_tag <> "hr" ORDER BY b.bbcode_tag' at line 1 [1064]
An SQL error occurred while fetching this page. Please contact the Board Administrator if this problem persists.
Please notify the board administrator or webmaster: [email protected]
Powered by phpBB® Forum Software © phpBB Limited
Has thanked: 6111 times
Been thanked: 15460 times
Re: Resource Limit
Click on your name, user profile, board preferences, you'll see Prosilver there.
Interestingly this is my first post on my laptop since yesterday afternoon as i've been stuck in limbo DNS land (as was @Rockburner ). But mine now seems to have come back at long last.
There's still things going on in the background as we're not quite there yet and @HiFi Kabin has still been tweaking things this morning and i've been back and forth on SMTP (Email) stuff with the Hosts...
Lets just say, this move/transition hasn't gone and smoothly as we'd all hoped.
Re: Resource Limit
Yorick wrote: Tue Jan 07, 2025 11:36 am Looks like the SQL code has been fucked up or rogue data in the database
General Error
Not exactly no, this is an 'extension' written by someone to provide a functionality, when we change versions, Hi-Fi or me has to update all of these extensions as code changes regularly when backend changes and versions are updated. It'll be a somewhat simple set of syntax that will need a quick edit... it's just a question of Hi-Fi and/or the extension writer to look into and resolve.
Weirdly that extension i wouldn't have thought would be related to the issue you're seeing, but is very useful
Part of the issue has been that not only did we have the CPU issue from the Hosts, we then migrated to a new Host server (which is more than just a quick move) and then had the PHP install updated, along with all the extensions etc...
So it's been 3 changes rather than what would usually be 1 change and then 1 in a few months...
So it's all got a little complicated
Re: Resource Limit
But please. Don't forget something important here.
@HiFi Kabin has a job.... like a real job... and gets paid buttons by us.. He just loves this stuff.
I get paid NOTHING for doing all this stuff, not even a cup of coffee...
So please take that into account :)
Re: Resource Limit
10 years since I was a DBA and these extensions are a mystery to me.
I often miss it as I was an SQL guru and ran classes for new starters.
HiFi Kabin
Re: Resource Limit
General Error
I have removed the outdated version of this extension and enabled a far newer version. @weeksy you may have to reconfigure it to how it was before as changing the extension has also removed the settings
Re: Resource Limit
We're doing the final bit of testing with internal email stuff, so lets see how that goes, but that shouldn't have any effects to you guys
