Page 33 of 63
Posted: Mon Feb 07, 2022 7:46 pm
Dazzler isn't worried about Ethanol, he's gonna run it on AVGAS.
Posted: Mon Feb 07, 2022 7:47 pm
Ethanol is currently a moot point cause it'll run on super unleaded. The 11:1 high comp pistons dictate that anyway and all the name brand super unleaded is ethanol free.
That said, I still fitted ethanol resistant seals and floats etc.
There's a way more fundamental reason I'll get it done professionally. Two actually. First off I really REALLY cannot be arsed with nasty chemicals and shitty sticky coatings, and secondly why TF would I spend thousands on all this repair/rebuild and then half arse the fuel system?
Posted: Mon Feb 07, 2022 7:49 pm
KungFooBob wrote: Mon Feb 07, 2022 7:46 pm
Back in his RAF days my FiL ran a Mini on AVPIN for about 5 mins.
https://en.wikipedia.org/wiki/Isopropyl ... prov=sfla1
Posted: Sat Mar 12, 2022 4:22 pm
by David
Well.....is it fixed yet?
Posted: Sat Mar 12, 2022 4:27 pm
David wrote: Sat Mar 12, 2022 4:22 pm
No
Been getting my house fixed.
Posted: Wed Mar 30, 2022 8:09 pm
I had a good old look at the 'leak' in the fuel tank this weekend - I don't think it is a leak. Upon deeper reflection I also remembered I brimmed the tank (in an attempt to mitigate rusting) before I put it away and it didn't smell of petrol at any point.
So I've put a blob of epoxy over the scrape in the tank followed by a patch of tape and decided I'll probably get it repaired fully in the winter. I've also now got some fresh fuel hose and a couple of inline filters so it
should just be a case of getting the tank back on and away we go. I can probably do that one day this week.
"Should".
Posted: Wed Mar 30, 2022 8:15 pm
by JackyJoll
You’re not me, but I put the reasonably big inline petrol filter in the hose, then cut off the blockage-prone gauzes from the tap and the carb banjos.
Posted: Wed Mar 30, 2022 8:28 pm
It did feel a bit pointless fitting extra fuel filters when you consider the air filters are just bits of wire mesh which stop you sucking in anything too big.
Posted: Wed Mar 30, 2022 9:55 pm
by JackyJoll
Fuel filters are to stop fuel starvation and/or flooding caused by dirt in the carburettors. Air filters are for reducing cylinder wear.
If you hsve the bellmouths with mesh over them, I may already have said this but they are worse than useless. They are restrictive, so they make the engine untuneable and they don’t filter dust out of the air.
Posted: Wed Mar 30, 2022 11:01 pm
by Cousin Jack
JackyJoll wrote: Wed Mar 30, 2022 9:55 pm
If you have the bellmouths with mesh over them, I may already have said this but they are worse than useless. They are restrictive, so they make the engine untuneable and they don’t filter dust out of the air.
My old BSA had a bellmouth and no filter at all. You could poke your finger in all the way to the slide and beyond. Perhaps the piston/cylinder clearance was such that the odd bit of grit didn't matter.
Posted: Wed Mar 30, 2022 11:14 pm
by JackyJoll
Cousin Jack wrote: Wed Mar 30, 2022 11:01 pm
Britain isn’t a very dusty place, generally, and it was easier to tune the old bikes with no air filter. You can do 20-40,000 miles with no filter.
But a filter is a good idea: you can have better compression and less oil consumption for longer and an appropriate filter is not very restrictive.
Those tea strainers over the intakes are restrictive and they don’t filter the air.
Posted: Wed Mar 30, 2022 11:31 pm
Nah they just stop you sucking up stones and leaves, thats it. On this bike you can see the intake valves when you open the throttle.
You can tell they do bugger all cause pre-rebuild this bike had a thick layer of what looked like tarmac all over the combustion chamber. Combination of burned oil and dust.
In theory bellmouths should get more charge in at high revs if they're properly tuned. That's why racers (both car and bike) use them. Dubious benefit on the road though, other than looking funky.
Posted: Wed Mar 30, 2022 11:37 pm
by slowsider
Thought the gauze was to prevent birds nesting...
Posted: Thu Mar 31, 2022 9:07 am
slowsider wrote: Wed Mar 30, 2022 11:37 pm
They're 'garage protectors' to keep mice out on bikes that are garaged for many months....
Posted: Thu Mar 31, 2022 9:49 am
by JackyJoll
I’ve seen it quoted from many reputable sources over the last 50 years, that the typical screw-on bellmouths give no power gain and are often worse than a bare carburettor.
Tuners claim they can
sometimes get a performance gain from the narrower “velocity stack” type, like this:
or by fitting the carburettor on a longer stub.
Trouble is, if you manage to get benefit from a resonance effect at one rpm range, you’re probably losing out at some other rpm.
Posted: Thu Mar 31, 2022 10:16 am
A lot of air boxes have velocity stacks inside them. Also a plate opposite the stacks. Air boxes are tunable using these, normally for bottom end and midrange. Open carbs or bellmouths are only useful for wide open throttle.
There was a time when people were experimenting with ramps in intakes. The idea was that the ramp turned laminar flow into turbulent flow and a resulting better mixture of A/F.
You're absolutely right about mesh covers. If you add up the surface area they actually take, you'll soon see why they are known as restrictive!
Posted: Thu Mar 31, 2022 11:02 am
Variable length velocity stacks are quite common in high performance engines, they're so effective they're banned in many motorsport series.
To me the mesh is just a practical thing to stop really big shit getting into the engine. As I said, at open throttle you can see all the way through to the back of the inlet valve, so you don't want bees/sticks/leaves/mice getting in there
Posted: Thu Mar 31, 2022 11:07 am
by JackyJoll
The authentic-looking air filters on late 1960s Triumph and BSA 650s are these and they are restrictive too, with a paper element.
They also develop cracks from vibration and fall to bits.
Posted: Thu Mar 31, 2022 11:40 am
by Rockburner
Mr. Dazzle wrote: Wed Mar 30, 2022 11:31 pm
IIRC My Dad once showed me the internals of the engine on the HRD (IIRC) after it had been making some strange noises, that suddenly stopped..... by the indentations he figured out that a rather large nut (probably the one missing from the tank mount) had fallen into the bellmouth, through the valve inlet, and then somehow found it's way out of the exhaust valve and rattled its way out the end of the exhaust.
Posted: Thu Mar 31, 2022 1:31 pm
by JackyJoll
Rockburner wrote: Thu Mar 31, 2022 11:40 am
The obvious advantage of a straight-through system!
