Page 1 of 1
Penetrating oils
Posted: Wed Jan 01, 2025 6:26 pm
by Sadlonelygit
need to replace a glowplug on the van. The internet says they need a damned good soaking in penetrating spray for a week before even looking at them.
Forums say pb blaster, which I can get, but is a bit pricey!
Others say 1:1 acetone and atf does the job.
Anyone with any experience of such things?
Re: Penetrating oils
Posted: Wed Jan 01, 2025 6:30 pm
I was always told plusgas was the best.
I've watched video on the tinternets of people using crayons and candles wax to get stuff shifted too.
Posted: Wed Jan 01, 2025 6:43 pm
by mangocrazy
I'd reach for the PlusGas in that situation, as well. If there's a well around the glowplug that the penetrating fluid can sit in, all the better. Carefully directed heat from something like a MAPP gas torch to the area immediately around the glowplug prior to squirting in the PlusGas (or whatever) will also help.
But yes, glowplugs have a bad rep fer seizing in place...
Posted: Wed Jan 01, 2025 6:55 pm
by Sadlonelygit
Apparently the regime is apply PF for a week whilst still driving around.
Pray to Mr Benz twice a day and don't use a mahoosive ratchet.
It would have been nice if it were one of the front plugs ie moderately accessible, but no, no4!
Posted: Wed Jan 01, 2025 6:59 pm
by Le_Fromage_Grande
I've WD40 branded penetrating oil (not WD40 itself) it worked well
Posted: Wed Jan 01, 2025 9:22 pm
by dern
I’ve never had to remove one but if I had to I’d take the car for a run to get the engine hot and then use plus gas on it and leave it for a while.
Posted: Wed Jan 01, 2025 10:05 pm
by Brickie
Vote for plusgas, soak plenty, don't rush. Let it cycle hot n cold with plusgas on it. Quite a few times.
Good luck
Posted: Thu Jan 02, 2025 1:29 am
by Felix
Only ever took them out with a hot engine and no oil. Yet to snap one but then again, i have only ever changed three sets and soon to be four.
Posted: Mon Jan 06, 2025 9:01 pm
by the_priest
PlusGas here. I used it on my totally rusted 23 yr old exhaust studs on the Triumph. Three weeks of spraying and heating with a bunson torch and then I used an extractor stud to remove them. They all popped out with no issues.
Posted: Mon Jan 06, 2025 10:08 pm
by ZRX61
AeroKroil for the win.
Posted: Mon Jan 06, 2025 10:17 pm
I can't believe no one has suggested KY yet. Iccy will be rolling in his grave!
Posted: Tue Jan 07, 2025 9:44 am
by Sadlonelygit
KungFooBob wrote: Mon Jan 06, 2025 10:17 pm
Does it cum with un chapeau speciale
Posted: Tue Jan 07, 2025 10:23 am
by v8-powered
I dropped a load of PlusGas down the glow plug holes on my VW CC a day before I changed them, they came out so easily without as much as a squeek.
Posted: Tue Jan 07, 2025 8:35 pm
by Sadlonelygit
wd40 penetrating oil has been bought. Need the weather to improve so I can crawl into the engine bay to start the spraying!
