Page 1 of 1
Coolant, are they all the same?
Posted: Mon Aug 02, 2021 2:50 pm
by YoKaiser
First ride of the year saw my radiator developing a hole l, anyway I've removed it and hopefully it's getting repaired. I'll obviously be filling with new coolant. Are there any particular products that are better than others? Bike is a street triple which does seem to run a little hot.
Re: Coolant, are they all the same?
Posted: Mon Aug 02, 2021 2:53 pm
There main types.
OAT
Glycol
Water
You don't want water because it freezes in the winter, expands and destroys stuff.
You shouldn't mix OAT and Glycol.
So... read your owners manual or speak to the stealership and ask which type you should use.
From an 'is one brand better than the next?' point of view.
No idea.
Posted: Mon Aug 02, 2021 3:30 pm
by Le_Fromage_Grande
Use whatever your manufacturer recommends, they aren't all the same, and some are better quality than others.
Posted: Mon Aug 02, 2021 3:39 pm
by Hairybiker84
I had issues with my Daytona 955i, really picky on coolant level and didn't take much persuasion to disgorge the header tank contents all over the floor. Changed the coolant to Evans (using the correct flushing fluid) and that was the end of the problem.
Posted: Tue Aug 03, 2021 5:28 am
by ZRX61
I use propylene glycol, engine runs 20deg cooler than with the ethylene variety. We also use it in RR Merlins. Sta-Clean brand intended for marine & big rig use.
Posted: Tue Aug 03, 2021 8:04 am
by Druid
Hairybiker84 wrote: Mon Aug 02, 2021 3:39 pm
My Speed Triples have been very fussy about coolant levels, anything above the minimum and it would spit coolant out. Must be a Triumph thing
Posted: Tue Aug 03, 2021 9:14 am
by DefTrap
You've just reminded me that at least two of my vehicles need a coolant change, so thanks!
Posted: Tue Aug 03, 2021 9:31 am
Druid wrote: Tue Aug 03, 2021 8:04 am
Mine too. It's got the second tank under the seat, it's never happy unless that tank is empty!
Posted: Fri Aug 06, 2021 4:48 pm
by Doc
Mr. Dazzle wrote: Tue Aug 03, 2021 9:31 am
Try removing the pressure cap and cleaning both the rubber seals and seats. There's usually some black flakes of paint or powder coat stuck to them, which leads to leaks under pressure (i.e. when hot).
