Page 1 of 2
Connecting a range cooker to the mains.
Posted: Tue Mar 14, 2023 11:29 am
by Mr Moofo
I have just bought a new (to me) range cooker, which is dual fuel. I have a gas man coming to connect it on Thursday. With the electrical connection - and I allowed to do this myself , or does this have to be open by a qualified electrician?
Re: Connecting a range cooker to the mains.
Posted: Tue Mar 14, 2023 11:50 am
by mangocrazy
If it's provision of a new circuit from the CU, then I believe this should be done by a qualified sparky. However if you feel you are competent and choose to do it yourself, I ain't tellin'...
If it's just connecting the appliance from an existing power point, I'm less sure. You (or whoever you employ) will need proper heat-rated cable to make the connection though.
Posted: Tue Mar 14, 2023 1:23 pm
by Mr Moofo
It would be using the cable that is in the current range cooker. Which is on a proper cooker power supply plug. It’s just as swap over
Posted: Tue Mar 14, 2023 1:31 pm
by Le_Fromage_Grande
Depends how confident you are working with a 30 amp supply, Couchy is the best person on here to ask.
Posted: Tue Mar 14, 2023 1:33 pm
Do it yourself, the gas bit too.
It'll only be a bayonet fitting, all the gas man does it check it's not leaking after plugging it in.
You can do that, if you wake up dead, it's leaking. If your house doesn't explode it's fine.
Posted: Tue Mar 14, 2023 1:34 pm
by Mussels
If you can wire a plug you can change a cooker supply.
The gas connection is even easier as it's just a push & twist plug.
Posted: Tue Mar 14, 2023 1:42 pm
by mangocrazy
Mr Moofo wrote: Tue Mar 14, 2023 1:23 pm
In that case JFDI.
Posted: Tue Mar 14, 2023 2:19 pm
by Mr Moofo
KungFooBob wrote: Tue Mar 14, 2023 1:33 pm
Can assume you have to turn it off at the mains - or does the bayonet have a valve on it?
Posted: Tue Mar 14, 2023 2:21 pm
Mr Moofo wrote: Tue Mar 14, 2023 2:19 pm
The socket is sprung valved, gas doesn't flow until you push the bayonet fitting in.
Don't blame me if you die in a fireball.
Posted: Tue Mar 14, 2023 2:46 pm
KungFooBob wrote: Tue Mar 14, 2023 2:21 pm
We'd hate for you to miss out on a monkey though.
Posted: Tue Mar 14, 2023 4:04 pm
by Mr Moofo
I might be giving it a go tomorrow!
Posted: Tue Mar 14, 2023 4:34 pm
by Cousin Jack
Mr Moofo wrote: Tue Mar 14, 2023 4:04 pm
If I hear a bang can I have the bike?
Posted: Tue Mar 14, 2023 4:38 pm
Cousin Jack wrote: Tue Mar 14, 2023 4:34 pm
If it goes bang! You get it. If there's a bzzzzztaaaaaagh! I get it.
Posted: Tue Mar 14, 2023 10:32 pm
by Mr Moofo
Posted: Tue Mar 14, 2023 10:34 pm
Mr Moofo wrote: Tue Mar 14, 2023 10:32 pm
Start to worry in a couple of hours when your canary dies.
Posted: Tue Mar 14, 2023 11:03 pm
by wheelnut
Mr Moofo wrote: Tue Mar 14, 2023 11:29 am
As has been said, you haven’t given enough info. Do you have a cooker socket to connect it to?
You sound unsure, so for what it would cost, get a man in.
Posted: Wed Mar 15, 2023 7:43 am
by Mr Moofo
It would appear that my wife has banned me from touching it.
Posted: Wed Mar 15, 2023 9:26 am
by mangocrazy
Mr Moofo wrote: Wed Mar 15, 2023 7:43 am
If the ban is permanent, I'd call that a win. You can never clean it or cook anything on it. It's the law...
Posted: Wed Mar 15, 2023 11:35 am
by Mr Moofo
mangocrazy wrote: Wed Mar 15, 2023 9:26 am
It was more the patronising " I would rather a professional does that"
Posted: Wed Mar 15, 2023 12:18 pm
by Mussels
Mr Moofo wrote: Wed Mar 15, 2023 11:35 am
Ask her to define professional, then ask how she will be checking their credentials.
For all she knows any Tom, Dick or Harry could be doing it, especially if she isn't there at the time.
