Page 1 of 2
Valve clearances time vs miles?
Posted: Thu Dec 21, 2023 1:25 pm
by dern
My assumption is that valve clearances don’t change over time, just miles. Is that correct? The bike I just bought has the valve clearances and rocker arms changed 2000 miles ago but 5 years ago. Leaving this and checking when it’s warmer but riding it in the meantime doesn’t seem like a high risk strategy… agreed?
Thanks
Mark
Re: Valve clearances time vs miles?
Posted: Thu Dec 21, 2023 1:26 pm
by weeksy
Wouldn't worry me in truth.
Posted: Thu Dec 21, 2023 1:27 pm
Mechanical things only wear through use.
Posted: Thu Dec 21, 2023 1:29 pm
by dern
That’s what I thought. I’ll change the oil and get using it. Cheers.
Posted: Thu Dec 21, 2023 1:32 pm
by Le_Fromage_Grande
The valve clearances tighten up because the valve springs stretch the valve stems, that doesn't happen when the engine isn't running, the the clearances get wider either the cams or the followers are wearing, again this only happens when the engine is running.
Wide clearances won't hurt the engine but you'll loose a small amount of power, tight valves will wreck an engine eventually.
Posted: Thu Dec 21, 2023 1:34 pm
by porter_jamie
Well and the seats recess too
Posted: Thu Dec 21, 2023 1:36 pm
by porter_jamie
Me being me I'd check them anyway as I'm sure it's not a tricky job. But they shouldn't have gone anywhere. Be good to have a look see what state the cam is in and see if there's any gravel and shit about
Posted: Thu Dec 21, 2023 1:51 pm
by JackyJoll
Do you believe this yarn about what was fixed five years ago?
Posted: Thu Dec 21, 2023 1:59 pm
by dern
I’ve got the receipts.
Posted: Thu Dec 21, 2023 2:21 pm
by Demannu
It's a KTM FFS.
The pixies will have been in there and changed EVERYTHING!
Posted: Thu Dec 21, 2023 2:43 pm
by porter_jamie
Lol
Posted: Thu Dec 21, 2023 3:32 pm
by JackyJoll
dern wrote: Thu Dec 21, 2023 1:59 pm
That certainly proves that they got some money.
If they did it at all, they probably did it wrong.
Posted: Thu Dec 21, 2023 4:16 pm
JackyJoll wrote: Thu Dec 21, 2023 1:51 pm
Are valve clearances like brake fluid, absorbing moisture over time?
Posted: Thu Dec 21, 2023 4:18 pm
by dern
JackyJoll wrote: Thu Dec 21, 2023 3:32 pm
Your optimism is an inspiration.
Posted: Thu Dec 21, 2023 4:24 pm
by David
Horse wrote: Thu Dec 21, 2023 4:16 pm
Yes, but they dry out when you use them.
Posted: Thu Dec 21, 2023 4:25 pm
David wrote: Thu Dec 21, 2023 4:24 pm
I tried an Italian tune up to try and get rid of the condensation muck in the crankcases. Didn't work.
Posted: Thu Dec 21, 2023 5:41 pm
by JackyJoll
I hope they don’t taste as bad as brake fluid.
Posted: Thu Dec 21, 2023 7:35 pm
by David
JackyJoll wrote: Thu Dec 21, 2023 5:41 pm
No, the heat drives the nasty off, they taste like a virgins bum.
Posted: Thu Dec 21, 2023 11:02 pm
by JackyJoll
David wrote: Thu Dec 21, 2023 7:35 pm
Female yeah?
I wouldn’t want to get caught out again.
Posted: Fri Dec 22, 2023 8:41 am
by David
Definitely. I have no experience of other types .
