irie wrote: Mon Apr 25, 2022 4:58 pm^^^ As you have previously said.Couchy wrote: Mon Apr 25, 2022 3:19 pmIn the peaks a 625 lasts 20-25 miles with 4000’ of climbing.irie wrote: Sun Apr 24, 2022 9:35 pm
Riding 20 miles uses less than 40% of a 500w battery so I guess effective range is over 50 miles, but then again I'm not trying to ride an eBike as an electric off-road motorcycle ...
Tbh I ride an ebike to go as fast as possible as you can’t use a motorbike in these areas anymore, i don’t understand having an ebike and not using it to its full assist. For the same effort as a normal bike you get lots more speed. Some of the climbs you would never make in eco mode and need turbo, with the extra assist you can tackle steeper longer stuff. If I was going slow enough/ easy terrain to make the battery last that long I wouldn’t have an ebike I’d just pedal.
There is much terrain, which you are clearly not interested in, which is gnarly, twisty, often rooty, and relatively slow which many riders are interested in, and which often requires steep ascents to reach.
Lots of slow tech stuff local and a lot of XC stuff too which I enjoy just as much, also all done in turbo/emtb, but we all ride for different reasons I just don’t see why I’d have an ebike and use eco. I’d rather a light normal bike or one of the lighter lower powered ebikes. Tbh tempted by an Orbea rise but would like to ride one first
