You would have to remove the connection to 87a and connect it, along with the existing connection, to 87 (so both wires are on 87 and none on 87a).
The old relay switches two circuits on and off together, the new one alternates between them.
Or, buy the correct relay, which would be the better solution.
Zimbo wrote: Tue Nov 01, 2022 5:37 pm
The old relay switches two circuits on and off together, the new one alternates between them. Or, buy the correct relay, which would be the better solution.
That's what I had tried to do, I thought I got the numbers matched !!
Would you be kind enough to let me know what I should be looking for, as I'd prefer the right relay if possible
They aren't that common, you need a double pole, single throw (DPST) relay, not a SPDT (changeover) relay, which is the replacement one you bought and the most common type.
