Who's got one, is it any good, what else would i need of i bought one, recommend one etc etc
All advice gratefully received as usual.
Don't think my experience will be much use. In various labs we had Grant ultrasonics but looking at them they're about 10x the price of stuff on Amazon (1 litre, unheated is over £500 inc VATRockburner wrote: Thu Jun 15, 2023 8:55 pm Talk to me!
All advice gratefully received as usual.![]()
Bear in mind that quoted volume is that of the tank. When the basket is in place, usable volume is a lot less, especially on the smaller sizes. My 5 litre tank would take a single carb, but only just. Below a certain size tank there isn't a tap fitted and you just have to pour the solution out, which is a faff and messy.Rockburner wrote: Fri Jun 16, 2023 11:18 am So - need a drain tap (hadn't thought about that, but it makes a lot of sense), probably worth getting one that is 2 or 3 litres or so (5 seems a bit big, would most likely only be doing smaller stuff, eg: single carbs ), and there's options on the fluid used.
Interesting - thanks all!
Found a 10l with a drain on Amazon with a 45% discounted price.... On its way.mangocrazy wrote: Fri Jun 16, 2023 11:40 amBear in mind that quoted volume is that of the tank. When the basket is in place, usable volume is a lot less, especially on the smaller sizes. My 5 litre tank would take a single carb, but only just. Below a certain size tank there isn't a tap fitted and you just have to pour the solution out, which is a faff and messy.Rockburner wrote: Fri Jun 16, 2023 11:18 am So - need a drain tap (hadn't thought about that, but it makes a lot of sense), probably worth getting one that is 2 or 3 litres or so (5 seems a bit big, would most likely only be doing smaller stuff, eg: single carbs ), and there's options on the fluid used.
The passages on the Monobloc are pretty wide I'll admit, and I've had a good go at them, but it all helps.Mr. Dazzle wrote: Fri Jun 16, 2023 1:51 pm If you're talking stuff for the JAP, I doubt you'll need ultrasound. The carbs are so bloody simple you can clean everything with a toothbrush pretty much! Anything you can't, you'll be replacing anyway probs.
Nice work! You'll be glad of the extra capacity - ya can't beat cubes...Rockburner wrote: Fri Jun 16, 2023 1:22 pmFound a 10l with a drain on Amazon with a 45% discounted price.... On its way.mangocrazy wrote: Fri Jun 16, 2023 11:40 amBear in mind that quoted volume is that of the tank. When the basket is in place, usable volume is a lot less, especially on the smaller sizes. My 5 litre tank would take a single carb, but only just. Below a certain size tank there isn't a tap fitted and you just have to pour the solution out, which is a faff and messy.Rockburner wrote: Fri Jun 16, 2023 11:18 am So - need a drain tap (hadn't thought about that, but it makes a lot of sense), probably worth getting one that is 2 or 3 litres or so (5 seems a bit big, would most likely only be doing smaller stuff, eg: single carbs ), and there's options on the fluid used.
Interesting - thanks all!![]()
