Rad cleaning
- Has thanked: 5970 times
- Been thanked: 3574 times
Rad cleaning
Gonna fit my rad guard tomorrow or the weekend. And seems my usual careful clean (careful as in trying not to touch it so rinsing from the rear) has left a few flies remains. Presume best method is gonna be a sponge/GT85 and careful wipe clean?
Although I'm sure they'll be replaced within a 100 miles.
- Has thanked: 8048 times
- Been thanked: 5698 times
Re: Rad cleaning
Stiff-ish bristle brush, hot water and WuL? The matrix shouldn't be that fragile.
- Has thanked: 2558 times
- Been thanked: 4168 times
Re: Rad cleaning
On one forum I was on, somebody suggested taking the rad off and immersing and soaking it in a solution that has protein remover in it (it's used by contact lens wearers). That should soften up all the bug carcasses which could then be removed by rinsing through (not with a jet-wash, obvs).
I've never tried it myself so it's effectively untested, but I thought it was an interesting take on removal of insect remains.
- Trinity765
- Has thanked: 3146 times
- Been thanked: 3189 times
Re: Rad cleaning
I cleaned my rad by soaking it in a big bucket and using a shower with no need for any special cleaners. It worked very well.mangocrazy wrote: Thu Apr 04, 2024 2:50 pm On one forum I was on, somebody suggested taking the rad off and immersing and soaking it in a solution that has protein remover in it (it's used by contact lens wearers). That should soften up all the bug carcasses which could then be removed by rinsing through (not with a jet-wash, obvs).
Otherwise, waiting until it's very warm and dry and using a dry brush works quite well.
Re: Rad cleaning
Soaking the rad in a bucket of warm water was what I did the last time I cleaned one, so the same as your option 1. This normally gets done when the bike needs a coolant change.Trinity765 wrote: Thu Apr 04, 2024 4:48 pmI cleaned my rad by soaking it in a big bucket and using a shower with no need for any special cleaners. It worked very well.mangocrazy wrote: Thu Apr 04, 2024 2:50 pm On one forum I was on, somebody suggested taking the rad off and immersing and soaking it in a solution that has protein remover in it (it's used by contact lens wearers). That should soften up all the bug carcasses which could then be removed by rinsing through (not with a jet-wash, obvs).
Re: Rad cleaning
There are only a very few so will see what I can do with as little pressure as possible. To be honest they must be so desiccated now I could probably pick em out with tweezers
- Has thanked: 2862 times
- Been thanked: 3518 times
