Broadband router regularly becoming inaccessible
roadster
Has thanked: 29 times
Been thanked: 214 times
Re: Broadband router regularly becoming inaccessible
Post by roadster »
mangocrazy wrote: Thu Aug 08, 2024 10:48 am
roadster wrote: Thu Aug 08, 2024 9:31 am The only thing I don't like is that TP-Link try to persuade you to use web/cloud based access for administration but if you insist on accessing settings locally it works fine.
192.168.1.1 FTW... :D
Being somewhat of an individualist I never use default IP ranges for my home network. But I do use ones that are not allocated for the www of course! When I accessed the router by address it used to prompt me for a TP-link web login at the first attempt but now it has stopped doing that and I go straight to the local login page.
Has thanked: 2557 times
Been thanked: 4168 times
It's crazy when viewed from a logistics standpoint. My router is no more than 1 metre from my desktop PC, and yet TP Link want to make me do a round trip of God knows how many miles/kms to access something that I can reach out and touch.
Utterly bonkers.
Has thanked: 779 times
Been thanked: 3223 times
How else will they intercept your traffic and sell the data?
MrLongbeard wrote: Fri Aug 09, 2024 10:48 am How else will they intercept your traffic and sell the data?
I never knew my router config data was so valuable...
mangocrazy wrote: Fri Aug 09, 2024 10:53 am
Config data, internet traffic, type of CPU or GPU you use, browser type etc etc etc all worth something to someone.
MrLongbeard wrote: Fri Aug 09, 2024 11:20 am
So are you saying that using a router's cloud config services then routes all my internet traffic through their cloud portal? And/or that TP-Link (in my case) is selling on my config data?
mangocrazy wrote: Fri Aug 09, 2024 11:24 am
I am not.
But it adds another step in the journey, another point of weakness, a unnecessary step, a step that costs them time and money, and I don't trust any company to give their time or money for free.
MrLongbeard wrote: Fri Aug 09, 2024 11:47 am
I am not.
We are in entire agreement on this. Which is why I always use local config.
The new TP-link modem/router has been in regular use for nearly a month now with no access issues, however Mrs Mango is now complaining that she doesn't have good signal strength everywhere in the house. I should have foreseen this...
The modem/router location is fixed as I CBA to rewire the house to put the router in a better place, so I'm thinking about repeaters/extenders. Are there any repeaters/extenders that allow you to connect back to my main router/switch via ethernet, then wifi extend the signal from that point? I've seen repeaters/extenders with ethernet ports but they mainly seem to be used to connect wired devices from the repeater/extender and not to use ethernet to receive the signal from the main router.
I've got a TP Link access point doing just that - I think it's a TL-WA801ND.
Been thanked: 1611 times
mangocrazy wrote: Sat Dec 21, 2024 7:17 pm The new TP-link modem/router has been in regular use for nearly a month now with no access issues, however Mrs Mango is now complaining that she doesn't have good signal strength everywhere in the house. I should have foreseen this...
Sounds like you need a couple of Mesh hubs - TP Link do some decent ones for not too much cash.
Has thanked: 8047 times
Been thanked: 5697 times
So it was OK, now it isn't? That's odd. Or is Mrs M now testing the signal in places she didn't go before? :hmmm:
Count Steer wrote: Sat Dec 21, 2024 8:31 pm
I think it was always iffy, but now I've fixed the lock up problem she's found something new to complain about... :D
The router is in a 'boxed in' position which probably limits wi-fi dispersion, but I'm not moving it.
I use wired... :)
Ah. Well, I've used a TP-Link booster thing that I put on the bedroom window ledge and that gave a decent signal down the garden to the cabin. Wasn't expensive and v simple to set up.
