Anyone got a cheap 3D laser level?
- Has thanked: 20886 times
- Been thanked: 13705 times
I could do with one of those 3d laser levels for a couple of projects I want to do this year. Anyone recommend a cheap one?
TIA
TIA
- Has thanked: 780 times
- Been thanked: 3224 times
Re: Anyone got a cheap 3D laser level?
Yep, I've got one, Amazon ASIN B08T87R8YS
Never used it mind
it was a drunken purchase after I found my spirit level had lost its bubble earlier in the day
Never used it mind
- Has thanked: 2852 times
- Been thanked: 1611 times
- Has thanked: 10971 times
- Been thanked: 4004 times
Yep, I've got a Bosch one. Very useful, as long as you can get it mounted at the right height.
- Has thanked: 781 times
- Been thanked: 1072 times
I bought a cheap Lidl one years ago and have used it many times, I just needed to add an old camera tripod to make it useful.
Based on that I suspect any cheapo one from Screwfix or Toolstation will be perfectly good.
Much better than spirit levels which I now only use for floors or the garden where it's too bright to see the laser line.
Yakking with a mate who said dont buy one as he has one I can use, but I dont like borrowing a working mans tools, iyswim and sods law he'll be using it the one time I do want it. So I'll get that one v8-powered linked to. I note the green light one is a £10 more, so I assume the green light is eaiser to see than the red one? The trades i've had working in the house have all had green light ones, so i'll go mad and spend the extra cockle!
- Has thanked: 2558 times
- Been thanked: 4168 times
The one that v8-powered linked to looks perfectly adequate for my usage. The cheapest ones from Screwfix start at just under £50 so quite a price difference. I still make plenty of use of traditional spirit levels and my new favourite is a bullet spirit level that has magnets in the base, brilliant when setting out steel stud work uprights for plasterboard.
Everyone knows green lasers are way cooler than red lasers.Taipan wrote: Fri May 23, 2025 10:27 am Yakking with a mate who said dont buy one as he has one I can use, but I dont like borrowing a working mans tools, iyswim and sods law he'll be using it the one time I do want it. So I'll get that one v8-powered linked to. I note the green light one is a £10 more, so I assume the green light is eaiser to see than the red one? The trades i've had working in the house have all had green light ones, so i'll go mad and spend the extra cockle!![]()
But you are correct, they are easier to see in a well lit environment, but use more battery power.
Used mine a few times and it's perfectly goodmangocrazy wrote: Fri May 23, 2025 10:34 am The one that v8-powered linked to looks perfectly adequate for my usage. The cheapest ones from Screwfix start at just under £50 so quite a price difference. I still make plenty of use of traditional spirit levels and my new favourite is a bullet spirit level that has magnets in the base, brilliant when setting out steel stud work uprights for plasterboard.
I do actually have the far cooler green version but when I purchased both were the same price.McNab wrote: Fri May 23, 2025 11:17 amEveryone knows green lasers are way cooler than red lasers.Taipan wrote: Fri May 23, 2025 10:27 am Yakking with a mate who said dont buy one as he has one I can use, but I dont like borrowing a working mans tools, iyswim and sods law he'll be using it the one time I do want it. So I'll get that one v8-powered linked to. I note the green light one is a £10 more, so I assume the green light is eaiser to see than the red one? The trades i've had working in the house have all had green light ones, so i'll go mad and spend the extra cockle!![]()
- Has thanked: 2296 times
- Been thanked: 2684 times
Got a green one that shoots 1, 2 or 3 lines. Great for hanging stuff on the wall & getting it centered/level/straight etc. Also enabled me to find out the garage floor has about a 3in drop across 26ft... which further aided me in getting the bottom of some shelf supports to match the slope & therefore have the vertical against the back wall & the bottom against the floor, sure beat that scribing malarky.
Batteries recharge via usb cord.
Huepar brand.
Huepar brand.
