Taillights
- Been thanked: 9505 times
Taillights
Are the days numbered for proper taillight units?
I was following a 16 plate Hardly the other day and the rear position lights, brake lights and the flashers were all done by a pair or rear indicators.
I saw a newish BMW GS today with the same setup.
I'm not sure if either was stock or aftermarket, but it kind of made sense. Even if an indicator falls off, you've still got the other to show a rear light and brake light.
- Has thanked: 780 times
- Been thanked: 3225 times
Re: Taillights
They were stock on my 18 plate Harley, and were one of the first things to be binned, what because they were the size of dustbin lids, back when we had dustbins that had lids;
Side by side by MrLongbeard, on Flickr
Side by side by MrLongbeard, on Flickr- KungFooBob
Re: Taillights
That stock indicator unit looks to have a full orange lens, how did it show a red position/brake light?
- ChrisW
- Has thanked: 3714 times
- Been thanked: 3027 times
Re: Taillights
Doesn't it make more sense to still have a rear tail/brake light that can't fall off?
Re: Taillights
but if it failed or fell off, then you'd have no position/brake light at all.ChrisW wrote: Sat May 24, 2025 6:26 pm Doesn't it make more sense to still have a rear tail/brake light that can't fall off?
- ChrisW
Re: Taillights
Fair point - I was focussing on the falling off bit, but yes, see what you mean. Using the indicators & having two does create a fail-safe.KungFooBob wrote: Sat May 24, 2025 6:27 pmbut if it failed or fell off, then you'd have no position/brake light at all.ChrisW wrote: Sat May 24, 2025 6:26 pm Doesn't it make more sense to still have a rear tail/brake light that can't fall off?
¿Por qué no las tres?
- ChrisW
Re: Taillights
Fair point, what with modern lights being made of led.
- Cousin Jack
- Has thanked: 3017 times
- Been thanked: 2529 times
Re: Taillights
I wish designrds of bikes and cars would recognise that putting lights close together (rear & indicator, brake and indicator) and making lights smaller are both very bad ideas.
How conspicuous an indicator in depends on the angle it subtends at your eye and the brightness relative to its surroundings. So small is bad, and putting them adjacent to another light is bad. Doing both is downright stupid.
- Has thanked: 7636 times
- Been thanked: 5937 times
Re: Taillights
Filly's old SEAT Altea had circular light clusters with the indicator at the centre. Brakes on, indicator invisible.Cousin Jack wrote: Sat May 24, 2025 6:51 pm I wish designrds of bikes and cars would recognise that putting lights close together (rear & indicator, brake and indicator) and making lights smaller are both very bad ideas.
Add to the 'stupid' list: indicators 'inboard' of the headlamp
FWIW
1. I was on a call with DfT. Indicators (rubbish quality of) was mentioned, the guy visibly flinched - obviously a contentious issue
2. There was conspicuity research about 20 years ago that recommended retro-reflective material should be a minimum of 150mm from lighting. Ignored, completely.
Re: Taillights
It does, really really bright LED's, jump to 2:20KungFooBob wrote: Sat May 24, 2025 6:23 pm That stock indicator unit looks to have a full orange lens, how did it show a red position/brake light?
Re: Taillights
Although looking back through my photos, maybe not that bright, the OEM really is pants compared to what I used to replace them (as I can see no one else in shot I assume that's marker light only)
Re: Taillights
I bought a Denali tail light on my scrambler, the LEDs are so bright that I had to stick a bit of parcel tape over it to dim it down.It does, really really bright LED's, jump to 2:20
