B&D Workmate - alternatives?
- Has thanked: 2558 times
- Been thanked: 4168 times
Re: B&D Workmate - alternatives?
The very first Workmates had cast aluminium legs and frame, as I recall. That fairly quickly got substitued for pressed steel, and then gradually all the good bits got swapped out for lower quality alternatives, the steel got thinner, the worktops were made out of MDF not laminated plywood etc. etc. When in France I use a B&D Workmate in conjunction with a pair of Stanley (plastic) saw horses and that covers most things. I also have a proper wall-mounted bench in the garage for heavy stuff.
- Has thanked: 8048 times
- Been thanked: 5698 times
Mine must be an in-between job. Pressed steelmangocrazy wrote: Thu Apr 24, 2025 10:04 am The very first Workmates had cast aluminium legs and frame, as I recall. That fairly quickly got substitued for pressed steel, and then gradually all the good bits got swapped out for lower quality alternatives, the steel got thinner, the worktops were made out of MDF not laminated plywood etc. etc. When in France I use a B&D Workmate in conjunction with a pair of Stanley (plastic) saw horses and that covers most things. I also have a proper wall-mounted bench in the garage for heavy stuff.
Cast alloy sounds like exactly what I want, but even wood would probably suffice.
Had an absolute Bismark of a bench at the last house - it was better built than the house
I was in the same case and I took a Wolfcraft Master 600, super light and very stable.
It holds under 11 kg and the jaws are great for clamping wood.
If you want bigger, the Master 700 is worth it too.
Well glad to have fired my old Workmate!
- Felix
- Has thanked: 717 times
- Been thanked: 2045 times
