Oi! Audiophiles! Budget starter turntable?
Has thanked: 7636 times
Been thanked: 5937 times
Foal now has my old stereo.
And 'old' is a fair description, Toshiba kit, bought in 1980.
Sadly, turntable no longer works. It was last used in 2020.
My guess is the drive belt has perished. Local repair shop man said he'd want £35 for an hour to check it, plus further repair and parts costs.
I've suggested to Foal that he has a look inside. Nothing to lose, really.
However, on the pessimistic basis that it's FUBAR, any suggestions for a starter / budget turntable?
Been thanked: 9505 times
Re: Oi! Audiophiles! Budget starter turntable?
I've got this one...
https://www.currys.co.uk/products/sony- ... J7EALw_wcB
I use it standalone with Bluetooth (headphones and Sonos), but it's got phono out so will work with your setup.
Has thanked: 2558 times
Been thanked: 4168 times
If it's belt drive, all you need to do is lift the platter off and check the state of the belt. It's probably turned to dust...
Replacement belts are available for just about any turntable ever made. I'll try and dig out the name of the guy I used a year or so back.
wheelnut
Has thanked: 929 times
Been thanked: 918 times
Post by wheelnut »
Rega Planar 1 or 2 is a good starting place.
This the guy I used. The website is from the late 90s, but he has a good 'how to' on how to get the platter off and measure the old belt:
http://www.gbaudio.co.uk/data/belts.htm
Has thanked: 1926 times
Been thanked: 1728 times
Where are you based ? I have a Projekt Debut One sitting in my attic
Mr Moofo wrote: Sat Sep 13, 2025 3:16 pm Where are you based ? I have a Projekt Debut One sitting in my attic
I'm in West Berkshire, Foal is in Leeds.
Has thanked: 8048 times
Been thanked: 5698 times
How budget?
I'd be checking the mileage to Moofo's place. :D
If the Rega Planars mentioned are a bit spendy the Audio Technica range is worth a look.
Have a look at John Lewis or, better, if you have one locally, Richer Sounds are a good outfit and v helpful and worth a visit. (Sevenoaks are OK).
Horse wrote: Sat Sep 13, 2025 3:35 pm
... But not averse to a day out :)
If you want a freebie , I am down in Brighton (ish). The deck works, need to find the weight to go with it. I replaced the platter as mine was warped ….
It’s not concourse condition …
Mr Moofo wrote: Sat Sep 13, 2025 7:12 pm
Thank you!
I'll PM you to arrange a date etc.
Mr Nozzle
Has thanked: 63 times
Been thanked: 51 times
Post by Mr Nozzle »
I can recommend Rega Plannar but be aware you have to manually move the belt to get from 33rpm to 45rpm or the other way round. Unless you buy 2 turntables and leave them on their respective settings.
Mr Nozzle wrote: Mon Sep 15, 2025 7:24 am I can recommend Rega Plannar but be aware you have to manually move the belt to get from 33rpm to 45rpm or the other way round. Unless you buy 2 turntables and leave them on their respective settings.
AFAIK, he only has albums.
NB in other news, he googled the deck. It's direct drive, no belt!
Horse wrote: Mon Sep 15, 2025 8:48 am NB in other news, he googled the deck. It's direct drive, no belt!
In that case, unless it's a Technics SL1200 (which it isn't) then it's almost certainly uneconomic to repair.
Collected :thumbup:
Great, friendly, supplier
Item as advised
Would use again
Horse wrote: Wed Sep 24, 2025 4:20 pm
Collected :thumbup:
Item as advised
Would use again
:thumbup:
Good buyer
Turned up on time
Wasn’t a care in the community candidate
This place works better that Facebook Marketplace !
If I hadn’t just had my rear molar ripped out by a greek dentist who looked suspiciously like Robert Downey Junior, I would have offered you a coffee and some biscuits!!
And yes, we bought the car …
