Descaling a kettle??
Has thanked: 1924 times
Been thanked: 1728 times
Re: Descaling a kettle??
Vinegar or citric acid will do it
Or as you are up a French mount, some cheap as chips Spar cola.
Any acid will break it down quite quckly ....
Trinity765
Has thanked: 3120 times
Been thanked: 3177 times
Post by Trinity765 »
ZRX61 wrote: Sun Dec 07, 2025 3:55 pm
KungFooBob wrote: Sun Dec 07, 2025 11:18 am Do what the septics do, boil your water in the microwave :)
That's because 110v kettles take a week to get *almost* to the boil. Expats bring 240v kettles from the UK, put a clothes drier/welder plug on them to run them at 220v.
They could use a stove top kettle :thumbup:
Been thanked: 9450 times
Get one of these instead...
https://ducati.cuisine-barista.com/
Been thanked: 2721 times
I didn't think the Americans knew how to boil water. Based on my trying to find a decent cup of tea over there.
Has thanked: 19484 times
Mr Moofo wrote: Sun Dec 07, 2025 5:11 pm Vinegar or citric acid will do it
When I was up hte mountain I didn't need the descale the kettle :lol: :lol: :lol:
But I'm not sure I can bring myself to buy any kind of cola !! :sick:
KungFooBob wrote: Sun Dec 07, 2025 6:13 pm Get one of these instead...
Not sure it's worth it - no probs with my coffee machine so unless the ducati jobbie makes a decent cup of Yorkshire Tea, not worth the money !!! :lol: :lol: :lol: :lol:
Has thanked: 781 times
Been thanked: 1068 times
Trinity765 wrote: Sun Dec 07, 2025 5:36 pm
Still slow unless they have a decent induction hob.
Noggin wrote: Sun Dec 07, 2025 7:46 pm
Do you want a cheap way to descale it or not?
Has thanked: 711 times
Been thanked: 2014 times
Buy and boil bottled water only.
Has thanked: 8005 times
Been thanked: 5664 times
Felix wrote: Sun Dec 07, 2025 11:06 pm Buy and boil bottled water only.
Or get a Brita water filter instead. I use one for all the water that goes in the kitchen kettle and the (now abandoned*) coffee machine.
Unfortunately, at £3.50-£4.00 a filter (if you use actual Brita filters) - a filter lasts a month - it's not the cheap solution that was requested.
*Gone back to filter coffee.
Trinity765
I have always lived in a hard water area and as far as I am aware it's not dangerous just annoying.
Mr Moofo wrote: Sun Dec 07, 2025 10:58 pm
:lol: Now I'm gonna have to see the difference between buying cola and buying citric acid :lol: :lol:
:shock: :shock: But, it's mountain water, just has a bit extra!! :lol: :lol:
Count Steer wrote: Mon Dec 08, 2025 8:07 am
I am considering that - mostly for the coffee machine. I suspect the cheapest option will be citric acid for the kettle - cos it doesn't need doing "that" often, it's just a smidge annoying when there's bits of scale in the bottom of the mug!! I always used to leave the last little bit of tea because of that, just out of practice cos haven't had to worry about it for so long being up high
Trinity765 wrote: Mon Dec 08, 2025 9:33 am I have always lived in a hard water area and as far as I am aware it's not dangerous just annoying.
Me too. It's not any kind of danger or risk I'm thinking of, it's purely the annoyance of getting scale in that last mouthful of tea :( :(. Need to practice leaving the last bit again :lol: :lol:
Slenver
Has thanked: 692 times
Been thanked: 919 times
Post by Slenver »
We live in a hard water area and my approach is multi-stage:
1. Make sure the kettle has a mesh filter in front of the spout so you don't get the bits going though
2. Get a little iron wool ball thingy to chuck in the kettle to attract the limescale. Got from La Range for a quid or so
3. Use the Oust stuff that the Count mentioned. Not only is it 100% effective at making the kettle like new, but fun too to see how close you can get to exploding the water out of the kettle without quite doing it.
4. Not give too much of a shit.
Zimbo
Has thanked: 101 times
Been thanked: 158 times
Post by Zimbo »
We live in a hard water area and I descale the kettle weekly, I use Kilrock descaler that I buy in Savers, works brilliantly. Boil kettle half full, transfer to sink, tip some descaler in and try to judge how much to add to get it to foam to the top but not actually over, leave five minutes, rinse, back to new again.
Mike1976
Has thanked: 4 times
Been thanked: 28 times
Post by Mike1976 »
Zimbo wrote: Mon Dec 08, 2025 5:59 pm We live in a hard water area and I descale the kettle weekly, I use Kilrock descaler that I buy in Savers, works brilliantly. Boil kettle half full, transfer to sink, tip some descaler in and try to judge how much to add to get it to foam to the top but not actually over, leave five minutes, rinse, back to new again.
The manufacturers can dress this up however they like, it's still just citric acid.
As with most "branded" items, they're not inventing new chemical elements. They're just rebranding existing well known agents as often as not making them worse with colourings, perfumes and dilutions.
Having said that if WD40 (paraffin) ever did make an aftershave, I'd be first in the queue.
I'd be lost if they invented an aftershave that smells like WD40 or CastrolR :wub: :wub: :wub:
Done before Christmas, but still a shiny inside on the kettle :) :) :)
Fanx boyz for being my mumsnet type advisors :wub: :bblonde: :bblonde:
Noggin wrote: Fri Jan 02, 2026 8:12 am Done before Christmas, but still a shiny inside on the kettle :) :) :)
Which method did you use in the end??
Count Steer wrote: Fri Jan 02, 2026 9:27 am
I got some citric acid from Amazon (couldn't be arsed to deal with people in an actual pharmacie!) - looked up the amount needed for a kettle and reduced by a third (cos my kettle is teeny tiny!) and boiled it, left it to cool
Wiped out with a kitchen scourer thingy (wiped, not scrubbed!) and all done :) :) :) :)
Taff
Has thanked: 332 times
Been thanked: 1183 times
Post by Taff »
I just noticed this morning that our water supply has changed again :x
Every now and then the water changes flavour a bit and the kettle stops furring up - that's come to an end :(
water = a rock smoothie according to Hannah Fry
