CDI READING,MAP PLOTTING AND PROGRAMMING
Dave G
Has thanked: 88 times
Been thanked: 71 times
Post by Dave G »
I put this info together a while back and thought it's about time I shared it!. Here's a few taster pics first to give you an insight.
[imghttps://themotorbikeforum.co.uk/uploads/monthly_2025_12/20250602_154032.jpg.259b0288920ebf11fcd6f1871402adbf.jpg][/img]
Here's the PDF I put together. Any questions?
https://themotorbikeforum.co.uk/applica ... 91af4fb4e6
Has thanked: 12620 times
Been thanked: 8541 times
Re: CDI READING,MAP PLOTTING AND PROGRAMMING
Any clues?
Dave G
Post by Dave G »
About what?
Dave G wrote: Tue Dec 30, 2025 6:27 pmAbout what?
I have absolutely no idea of what any of it is about.
Dave G
Post by Dave G »
Yorick wrote: Tue Dec 30, 2025 7:11 pm
I got rid my ECU and replaced it with a CDI unit when I did a carburettor conversion. I initially used a standard off the shelf CDI unit designed for use with NC450 sohc engine. When I upgraded to the NC450S dohc engine I wasn't sure whether the CDI would or wouldn't be compatable so I decided to go for a programmable CDI to allow me to experiment. The pdf that I attached to the first post explains how I did this. Any questions!, please ask.
Dave G wrote: Tue Dec 30, 2025 7:17 pm
That was complete Chinese to me. I'll leave you to it.
Dave G
Post by Dave G »
Maybe this isn't the right place for this kind of stuff!
Dave G wrote: Tue Dec 30, 2025 7:44 pm Maybe this isn't the right place for this kind of stuff!
I've been riding and fettling bikes 50 years and never come across this before.
Has thanked: 8048 times
Been thanked: 5698 times
I'm sure there'll be some interest, it's just a bit of a quiet time as people finish digesting their sprouts and stiffen the sinews ready for NYE. :)
Dave G
Post by Dave G »
Count Steer wrote: Tue Dec 30, 2025 8:02 pm
If there's anybody out there wanting to replace there CDI with a programable variety so that they can play around with the ignition timing but revert back to standard ignition if things don't work out! then this PDF might be a good bedtime read.
Has thanked: 2558 times
Been thanked: 4168 times
I'd have been interested to read the PDF, but when I clicked on the link I got this message:
This attachment is not available. It may have been removed or the person who shared it may not have permission to share it to this location.
Dave G
Post by Dave G »
Anybody else struggling to download PDF. Maybe it's me doing something wrong. I tried it as an attachment first but it wouldn't allow me to do so!
Dave G
Post by Dave G »
Am I allowed to attach PDF's to a post?. Some forum's seem to allow it!
Dave G
Post by Dave G »
Lets see if this works!
Been thanked: 9505 times
Hi Dave!
The NC450 sohc, is that the Zongshen engine that's very similar to the old Honda RFVC lump?
What was the driver for replacing the EFI throttle body with a carb?
Have you considered points over CDI (thats a joke btw)?
Dave G
Post by Dave G »
KungFooBob wrote: Tue Dec 30, 2025 8:56 pm Hi Dave!
I'm using the NC450s engine now which is basically the same as the NC450 but DOHC. I think the NC450 is an early Honda CRF450 copy. The story behind the conversion is here.
https://www.motoblog.it/post/fantic-cab ... ve-gillery
Oh, I remember who you are now!
Instead of a carb, did you consider a custom EFI setup, like a megasquirt?
Dave G
Post by Dave G »
KungFooBob wrote: Tue Dec 30, 2025 9:17 pm Oh, I remember who you are now!
I developed a system to modify the fuel injector times, but still had reliability issues with ECU so decided to get rid of ECU and all associated sensors and replace with CDI and carb. This bike review talks about it.
https://www.bikebound.com/2025/09/13/dohc-caballero/
crust
Has thanked: 964 times
Been thanked: 713 times
Post by crust »
Which CDI did you use? Was it from these people?
https://www.ignitech.cz/en/
Dave G
Post by Dave G »
crust wrote: Wed Dec 31, 2025 12:12 pm Which CDI did you use? Was it from these people?
Yes, it's this one.
https://www.ignitech.cz/en/vyrobky/dccdip/dccdip.htm
