DIY Quickshifter
Dave G
Has thanked: 88 times
Been thanked: 71 times
DIY Quickshifter
Post by Dave G »
Here's some quickshifter information that I put together after I'd fitted it to my Fantic Caballero 500. No reason why it couldn't be used on other single cylinder bikes. Hope you find it interesting!.
Quickshifter mech at rest.jpg (61.05 KiB) Viewed 538 times
Quickshifter mech gear up.jpg (58.93 KiB) Viewed 538 times
Dave G
Re: DIY Quickshifter
Post by Dave G »
Anybody out there made their own quickshiter?. Would be nice to get some more pics!
Dave G
Post by Dave G »
Any comments?
Has thanked: 20885 times
Been thanked: 13705 times
Think you're a lot more mechanical capable than most on here! We mainly ride, break or crash 'em! ;) :D
Dave G
Post by Dave G »
Taipan wrote: Tue Feb 03, 2026 1:52 pm Think you're a lot more mechanical capable than most on here! We mainly ride, break or crash 'em! ;) :D
The aim is to inspire others to tinker!. Need to do more riding though when the weather improves
Has thanked: 3022 times
Been thanked: 1750 times
A quickshifter does a bit more than just move the great lever, stuff like cut the ignition during the shift. If you want it to work on the downshift you'll need a slipper clutch as well. There's probably a bit more to out as well.
On the bikes I've ridden that were fitted with a quickshifter I've found them best used at higher revs, they're not for around town use.
Dave G
Post by Dave G »
Pirahna wrote: Tue Feb 03, 2026 4:14 pm A quickshifter does a bit more than just move the great lever, stuff like cut the ignition during the shift. If you want it to work on the downshift you'll need a slipper clutch as well. There's probably a bit more to out as well.
The one Iv'e made works just on upshifts and cuts the ignition for a time period setup in the Ignitech CDI.
Ignitech_clutch master.jpg (166.87 KiB) Viewed 472 times
Been thanked: 14171 times
Cool work man. Way ahead of most tinkerers on here.
Dave G
Post by Dave G »
Skub wrote: Tue Feb 03, 2026 9:05 pm Cool work man. Way ahead of most tinkerers on here.
Hope it gives others inspiration to tinker!
Dave G
Post by Dave G »
Share permissions changed, hope that the PDF is now accessible!
