E-bike motors and the arms race of power !!
Has thanked: 6113 times
Been thanked: 15462 times
Re: E-bike motors and the arms race of power !!
Wow, once again it's insane in the arms race with pretty much everyone now going full Avinox.
From Orange bikes, Mondraker, Canyon, Nukeproof, it just seems like manufacturers have decided that Avinox is the way forward and the only way to go. Most it seems are running the M2S which is the higher power 1500w, but some are going 1200w with the M2.
It really doesn't help me in the fact that i still want and will own an eeb. But i'd rather stay away from Avinox through personal preference, but it's lowering my list and options all the time.
Couchy
Has thanked: 360 times
Been thanked: 2246 times
Post by Couchy »
Power aside the avinox delivery is superb and miles better than my Bosch, it takes measurements 42 times a revolution where the Bosch does it once. You can have zero overrun when you stop pedalling or adjust it to run on in increments. You can set max torque and power at loads of different levels, you can set how quick it responds too. It’s also lighter than the Bosch. If you don’t want the power you could set it to the same as any of the lower powered bikes in one mode. The way it rides is utterly superb and infinitely adjustable there’s just no way I can see why anyone would buy another brand.
Couchy wrote: Thu Jun 25, 2026 3:08 pm Power aside the avinox delivery is superb and miles better than my Bosch, it takes measurements 42 times a revolution where the Bosch does it once. You can have zero overrun when you stop pedalling or adjust it to run on in increments. You can set max torque and power at loads of different levels, you can set how quick it responds too. It’s also lighter than the Bosch. If you don’t want the power you could set it to the same as any of the lower powered bikes in one mode. The way it rides is utterly superb and infinitely adjustable there’s just no way I can see why anyone would buy another brand.
The big reason for that for me is known reliability and support, both short and longer term. But maybe by the time i get one that will change anyway.
Couchy
Post by Couchy »
They’ve been out a couple of years and so far so good, I can only imagine with so many jumping on the bandwagon it’ll all work out, my Bosch has been great but at 4 years old needed new bearings which I decided not to do and put a new motor in. I didn’t mind as it’s done every mile in turbo 🤣
Couchy wrote: Thu Jun 25, 2026 3:21 pm They’ve been out a couple of years and so far so good, I can only imagine with so many jumping on the bandwagon it’ll all work out, my Bosch has been great but at 4 years old needed new bearings which I decided not to do and put a new motor in. I didn’t mind as it’s done every mile in turbo 🤣
Not really. There's many many issues on various forums with them, including the M2S, from hardware issues, to rattling and software loss of connection or drive etc...
The Bosch have that fact that you can rebuild easily.
mboy
Has thanked: 849 times
Been thanked: 695 times
Post by mboy »
2 new MGU's launched at Eurobike this week... The Avinox MG and the Gobao X1P...
BOTH running fully CVT transmissions inside!!! Sounds like both will be able to be overridden and have user selectable artificial ratios if required too...
Yes, yes, yes... Predictably too much power and torque etc... But can be turned down of course...
Consider my interest piqued! Certainly I might end up moving my Crafty on sooner than later to make a space in the garage for a next gen MGU powered bike as and when they become available... 🤔
Has thanked: 3633 times
Been thanked: 2494 times
Agreed, no more wearing out an expensive cassette in a few hundred miles.
MingtheMerciless wrote: Sat Jun 27, 2026 2:18 pm Agreed, no more wearing out an expensive cassette in a few hundred miles.
But wearing out a way more expensive gearbox ? Mmmm
I still thibk the pedal system/cranks are a massive weak spot because of how they need to spin. But also need to be sealed from mud and water
mboy
Post by mboy »
weeksy wrote: Sat Jun 27, 2026 2:52 pm
For real...? :lol:
Internal gearboxes on MTB's are many, many times stronger and more durable than any derailleur and cassette system... The Pinion MGU for instance, the only maintenance is an oil change once every 10k km (6200 miles)...
OK, when the bike is 10yrs old, had 5 different owners, a patchy service history etc. it might become Caveat Emptor for a prospective new owner (just like a 10yr old car or van I guess), but if like most of us, you're buying a new bike to last you anywhere from a year to 5 years before you're then likely to upgrade with another, gearboxes will all but eliminate maintenance and replacement drivetrain parts on eBikes!
Why isn't anyone using a Pinion then? (Yes I know a few are)
Its not like ebikers are short of a bob or two.
mboy
Post by mboy »
Cos it came out late, it's heavy, very noisy, low on power and torque for the market etc... Despite all that I still very nearly bought one... In fact, if I didn't ride with people on more powerful bikes, I would have bought one, but the thought of artificially handicapping myself on purpose when I need to keep up on the climbs with people who simply won't turn their bikes down from full power doesn't bear thinking about!
Most people only care about the power and torque figures... Nothing else! Pinion is on 85Nm and 600W, which is where everyone else was prior to the Gen5 Bosch CX and the subsequent arms race ignited by Avinox...
FWIW I just had a quick spin on a mates Mondraker Zendit with the Avinox M2S motor just now, 130Nm and 1300W peak... Absolutely ludicrous! After 20m I couldn't wait to turn it down...
Couchy
Post by Couchy »
weeksy wrote: Sat Jun 27, 2026 4:50 pm Why isn't anyone using a Pinion then? (Yes I know a few are)
Can’t derestrict it reliably, I think I only know one person that has an ebike still restricted, 15mph isn’t enough 20mph would have seen plenty happy with that.
crust
Has thanked: 953 times
Been thanked: 709 times
Post by crust »
Couchy wrote: Sun Jun 28, 2026 1:35 pm
Two - my Rail is still restricted, no point derestricting it, the old boy struggles to keep up as it is :D
Spends most of its time in Tour.
Taff
Has thanked: 332 times
Been thanked: 1183 times
Post by Taff »
Three, my Whyte had never been derestricted.
Not that it matters much because I rarely use it because I prefer my manual.
crust wrote: Mon Jun 29, 2026 11:37 am
I don't struggle to keep up... i struggle to even NOT keep up :D
Couchy
Post by Couchy »
You were the one I know 🤣
I'm thinking about hiring an eeb this week, but my shame factor is kicking in. We're over doing FoD Thursday for 3-4 hours on the evening and it's £35 for hiring for that time which is pretty decent money really. But can I face the walk of shame to go and collect an eeb... I dunno. But it will maximise my riding and the number of laps i can get done for sure.
Talking to LBS owner , Goboa who had a combined motor/gearbox unit on show are also doing a new motor that will fit Shimano EP8 motor mounts. More power and torque along with more energy dense batteries that fit Shimano patterns. Whether you can mix and match between both manufacturers I don’t know but if I could swap out the motor on the Evil when it dies for a more grunty unit rather than buying a new eP8 that would be very tempting
Couchy
Post by Couchy »
weeksy wrote: Tue Jun 30, 2026 7:01 am I'm thinking about hiring an eeb this week, but my shame factor is kicking in. We're over doing FoD Thursday for 3-4 hours on the evening and it's £35 for hiring for that time which is pretty decent money really. But can I face the walk of shame to go and collect an eeb... I dunno. But it will maximise my riding and the number of laps i can get done for sure.
There’s only you that cares these days, hold your head high and bathe in the glory of not being a poor person on a manual bike 🤣
Has thanked: 1924 times
Been thanked: 1728 times
MingtheMerciless wrote: Thu Jul 02, 2026 5:04 pm Talking to LBS owner , Goboa who had a combined motor/gearbox unit on show are also doing a new motor that will fit Shimano EP8 motor mounts. More power and torque along with more energy dense batteries that fit Shimano patterns. Whether you can mix and match between both manufacturers I don’t know but if I could swap out the motor on the Evil when it dies for a more grunty unit rather than buying a new eP8 that would be very tempting
Can’t help but think this will be a way to go for motor manufactures
Shame it’s not Bosch1
