Tyre pressures
Has thanked: 2980 times
Tyre pressures
Had a ride out after several months of inactivity, and I didnt check my tyre pressures. Bike felt fine, perhaps a bit more compliant over the bumps, but totally fine in bends. Perhaps more planted than usual.
Checked them today and they were about 32, front and rear. Pumped them back to 36/42 which is normal. It will be interesting to see if I fel any difference.
I know track day gods reduce pressures for hard riding, but I don't ride hard. What pressures do others use?
Has thanked: 8004 times
Been thanked: 5663 times
Re: Tyre pressures
Only time I paid much attention beyond that was to check the pressures fully loaded before setting off touring.
I've always assumed the the lower track pressures are because the tyres get hotter and that the actual operating pressure is, pretty much, the same as on road.
Gregor
Has thanked: 1755 times
Been thanked: 1151 times
Re: Tyre pressures
Post by Gregor »
30/32 on the xt660z
33/42 on the K100
Has thanked: 2554 times
Been thanked: 4158 times
Re: Tyre pressures
Official Falco pressures are like everything else, 36F/42R but I prefer 32F 36R for solo riding. If I take a pillion its 36F/42R.
KTM specify 2 bar (29 psi) F & R for the 690 Duke, so that's what I use.
And for the LC it's whatever Haynes recommends (I forget every time and have to check).
Has thanked: 2844 times
Been thanked: 3495 times
Re: Tyre pressures
Monkeys 29 both ends. Implying it's to do with weight, why they're all 36/42 i have no idea.
wull
Has thanked: 976 times
Been thanked: 1846 times
Re: Tyre pressures
Post by wull »
My last set of tyres were run at 32psi front and 26psi rear, the pressures were displayed on the dash usually showing within 1psi of what I had set them to.
Re: Tyre pressures
I hope to go out to play tomorrow, so I will see how they feel. Seems that reducing them a bit when I have no luggage might be worth a try.
Has thanked: 10930 times
Been thanked: 3972 times
Re: Tyre pressures
I seem to remember the consensus a few years ago was "check what the tyre manufacturer recommends".
The premise presumably being that they'd tested their tyres on bikes of varying weights and so could give a very close estimate of the ideal pressure for the weight of bike.
That's what i used to go on, and tended to be very happy with.
But on further introspection, there are a few issues with that premise. Different people ride in different ways, and different bikes with varying suspension setups handle in different ways. Who can guarantee that they ride the exact same way as Pirelli's development testers, on the same suspension settings on the same bikes, on the same tracks?
So, I tend to stop go for the tyre manufacturer recommendation, but as a starting point, and then if things feel a bit off, make small changes both ways too see what improves the ride experience.
asmethurst99
Has thanked: 1326 times
Been thanked: 482 times
Re: Tyre pressures
Post by asmethurst99 »
Noticed a bit of understeer last week and thought maybe the rear was squaring off .
Checked the pressure and it was quite a bit off.
Has thanked: 5933 times
Been thanked: 3551 times
Re: Tyre pressures
Usually just go 36/42 as that's what's in the GSXS manual. I've noticed when playing that much lower in the front makes the steering feel slow, on the back I can go a fair bit lower without much change so typically run 42 but don't sweat to much if it was say 38.
Scotsrich
Has thanked: 92 times
Been thanked: 820 times
Re: Tyre pressures
Post by Scotsrich »
Tyre pressure monitors are both an evil and a great thing.
i can’t recommend the last time i checked either the car or the bike
Been thanked: 3207 times
Re: Tyre pressures
36 front 40 rear for the Harley, thankfully it doesn't have TPMS, I just check it once a week.
Has thanked: 12553 times
Re: Tyre pressures
Folk worry too much about tyre pressures. If it feels OK, let it be.....
On my GSXR1000 the road pressures are
F 36
R 42
On track..
F 32
R 21 (yes, half)
Last time I checked the pressures was at Portimao 2 weeks ago
I went out yesterday and had a great ride. Forgot that they were set for track.
When I was instructing in the UK, I always left the tyre pressures on track settings and it was always OK on road.
The only time I ever check them is if I'm taking the missus out.
BTW I took my heat gun thingy at Portimao and checked the pressures after a session on track.......
Front
60 middle
65 edge
Rear
70 middle
75 edge
Re: Tyre pressures
I think solo riders could go quite a bit down on their pressures if they wish to do so, but in real world road riding, does it matter one way or tuther. 🤷‍♂️
Re: Tyre pressures
My rubber coated screw repair still holding air. 👍
Been thanked: 4527 times
Re: Tyre pressures
36/42, 35/35 for trackdays if I can be arsed to change them
MyLittleStudPony
Has thanked: 827 times
Been thanked: 583 times
Re: Tyre pressures
Post by MyLittleStudPony »
I go for something like 12 psi in both for day to day use. That's because I'm always hoying the front and ganning the back.
Has thanked: 711 times
Been thanked: 2014 times
Re: Tyre pressures
Cant even tell you what book recommends. Thumb test says its not soft so good to go and the bike sticks like shite to a blanket on the bends.
Quick Google says 36/42. Ill set them like that for the weekend and see how far out my thumb test is :lol:
Whysub
Has thanked: 1276 times
Been thanked: 1014 times
Re: Tyre pressures
Post by Whysub »
I have TPMS and temperature readout on my new scooter.
Interesting to see how much the tyre temperature went up when I deliberately rode behind a lorry on the motorway. And then seeing the temperature drop when I was riding with no vehicles in front of me (even though air temperature was 38°c).
Made a couple of psi difference upwards when behind the lorry. Not quite sure how it makes that much difference to a MotoGP bike when behind another rider, enough to penalise a rider at least.
Re: Tyre pressures
Felix wrote: Thu Jul 09, 2026 11:20 pm Cant even tell you what book recommends. Thumb test says its not soft so good to go and the bike sticks like shite to a blanket on the bends.
So they were 19.5/24.5 :1 Here was me thinking my lean was quite impressive as well. Turns out my tyre was to soft :lol: :lol: :lol:
