Tricky
Has thanked: 3045 times
Been thanked: 3309 times
Post by Tricky »
Great thread, look forward to seeing it finished, and I'd love a go on it (although probably just one go :D ;) )- maybe when it's done, and my 350 is, I'll ride over your way and we can stink up some Hants/Surrey roads with the lovely smell of 2 strokes 8-)
Nidge
Has thanked: 684 times
Been thanked: 673 times
Post by Nidge »
Is it finished yet?
Has thanked: 1059 times
Been thanked: 1646 times
Just bad a phonecall offering to buy my "spare" KX500 today.
It's one I bought quite some time ago just for the spares and haven't ever ridden, its been flipped so the rear subframe is knackered and is in a condition best described as tatty.
I got it then thought it was so close to being a full bike that I'd get the rest but have never quite had the time and money to do it.
I've still got my main one and a fair selection of spares so I'm not short of gear and at the moment the money is more important.
Ive ratched out a load of parts and think the price is fair to both ends of the deal, to me and the buyer.
A_morti
Has thanked: 412 times
Been thanked: 824 times
Post by A_morti »
derek badger wrote: Wed Mar 25, 2020 8:43 am I've now got a set of 17" wheels and some part worn tyres so the bike is at least manoeuvrable around the garage. I can't for the life of me remember what they're off, (the front it a Honda but running reverse so the brake disc is on the correct side).
Front is off a CB-1!
You've unfortunately picked a kinda heavy wheel with a disc that's unique to the model, and not easy to find.
If you are willing to drill their bolt holes out to 8mm, a carby Blackbird disc will fit but it's thinner material. You can also go down to 296mm and use all sorts of Honda discs (600f3 for example).
derek badger
Has thanked: 1091 times
Been thanked: 1762 times
Post by derek badger »
A_morti wrote: Wed May 27, 2020 2:40 pm
Probably easier to swap both wheels out for something more suitable. They were slung on there as they were cheap and I got the tyres free.
Has thanked: 20886 times
Been thanked: 13705 times
Nidge wrote: Thu Mar 26, 2020 3:28 pmIs it finished yet?
If I was a betting man, my money would be on the Segrada Familia being finished first... :lol:
Been thanked: 9505 times
Taipan wrote: Tue Jun 09, 2020 7:22 pm
They reckon it'll be finished in 2026, so it's probably a sound bet.
Been thanked: 4529 times
He's been building it for as long as I've known him online, which is approaching 20 years.
derek badger
:thumbup:
Been thanked: 14171 times
Are we there yet? 8-)
KungFooBob wrote: Tue Jun 09, 2020 7:43 pm
That's the Spanish estimating a finishing date, so no one actually believes it. We have decadas de mananas left yet! :D
derek badger
So...
I'm kind of stuck having dropped the clutch basket and broken a pawl off...which I have subsequently lost/thrown away. It's a discontinued part and I've not seen one pop up on eBay in the last 6 months.
The 1985 clutch basket shares the same steel and friction plates as the 1986 and others but it has a 16T crank gear and the later ones have a 17T so I bought one thinking I could press them out and swap. Unfortunately they have a different number of splines. The large gears are the same in both.
So, it's an engineering shop job. My thoughts are either cut a pawl off the 86 basket and get it TIG welded on to the 85 basket and machined up, or press out both gears and build up the 86 basket with weld and rebroach it for the splines of the 85 crank gear.
Anyone have any other thoughts?
I'd probably make a new middle bit with the gear off one and the spline off the other, IYSWIM
Cutting gears and splines is a bit spendy though if you're not in the habit of doing it.
Why is it a spline? Does it have to be?
Edit: Ah right, it's an aluminium basket and a steel gear innit...makes sense. That's why it's splined. If you did it another way you'd chew through the basket.
So yeah. Make a new 'hybrid' centre bit or build up and remachine as you say. If it were me I'd have more faith in the former than the latter.
derek badger
Well fuck my hat. Just found a KX500 specialist on Facebook, pinged him a message thinking he'd get back to me next week. Replied straight away...turns out not only is he 20 miles down the road from me, but he's located a NOS basket in Holland for £250.
derek badger
Been thanked: 15510 times
Great news Badger :)
Get it done ASAP and get it shipped over...
I forget now, where else are you up to with the bike ?
derek badger
weeksy wrote: Sat Jan 02, 2021 7:27 am Great news Badger :)
Engine fully rebuilt, then the kickstart spring went while trying to start it (no spark). Broke the clutch replacing that. Once it's bolted back up I've got a new coil and CDI unit, check the points/condenser and get it running. It's then brakes, chain alignment, wheel spacers etc. which I'm more than happy with doing. If I can find a cheap set of spoked 17" wheels and better forks I would like to swap them.
I'll crack on with the paperwork to get it registered next week.
derek badger
Oh, and torque up, thread lock and lock wire everything. It's amazing how much a big bore 2stroke vibrates.
Bigyin
Has thanked: 1436 times
Been thanked: 2738 times
Post by Bigyin »
derek badger wrote: Sat Jan 02, 2021 10:11 am
Just quoting this so that when a squirrel goes past the garage and your attention span drifts we have something to point you back to ;)
Could it finally be finished ?, really? actually done?
time to break out one of weeksys new smilies
:banana-wrench:
A mate had one of those a few years ago. I asked him was he not wary of it on the dirt,he said nah,just pin it and hope tae fuck it never gets grip. :shock: :lol:
