- Been thanked: 14171 times
Salty enough for 15 years ago.
- Been thanked: 9505 times
I remember buying woodruff keys almost weekly when I commuted on a string of 100cc shitters in my late teens.
- derek badger
- Has thanked: 1091 times
- Been thanked: 1762 times
Yea, that's what I thought. The price of NOS parts now makes me cry. It's been a heavy investment this project, but as you mentioned before...it's been spread out over a long period of time!
The other tyre should arrive tomorrow, I'll take them to be fitted Friday if my mechanic is about.
Another new coil arrives tomorrow after the multimeter showed it wasn't in spec. Then I'll check the stator readings, it's new and unused...but at least 10 years old. Then that's all the ignition replaced, if it still won't start I'll look at the fuel system again as compression certainly isn't an issue.
- derek badger
Horn and button, speedo, kill switch and fusebox all arrived and put with the other wiring bits. 'Daytime' MOT to start, then I might look at basic lights. I've got 4 x 3.7v NiCd cells out of a head torch that might be of use wired in series. A generic reg rec might be another option to convert the AC lighting coil output. I'm getting ahead of myself though, but it's cathartic to buy parts during lockdown...
- derek badger
Got the tyres, tubes and rim tape fitted today.
Some more wiring tomorrow and continue to try and start it.
- derek badger
Oh hell no, I can't stand that tat!Potter wrote: Sat Feb 20, 2021 2:46 am When you said rim tape I shuddered and expected to see green tape around the rims, but ISWYM.
- derek badger
It's just storage dust, they were brand new when fitted. The whole thing will get a good wash soon.GuzziPaul wrote: Mon Feb 22, 2021 4:22 pm Them lime green gators look a bit manky next to the nice wheels and tyres.
- derek badger
Because the sun was out I put it's clothes back on and gave it a bit of a wash.derek badger wrote: Tue Feb 23, 2021 7:16 amIt's just storage dust, they were brand new when fitted. The whole thing will get a good wash soon.GuzziPaul wrote: Mon Feb 22, 2021 4:22 pm Them lime green gators look a bit manky next to the nice wheels and tyres.
Still not got it started though, it fires most kicks but only runs for a second or two at the most. I've had the carb apart (again) and checked the jet sizes are mixture screw are correct and it's got a reasonable spark. I guess it's just perseverance but I end up a sweaty mess and I've bruised the fuck out of the left side of my right knee after bashing it on the exhaust a couple of times. I'll be keeping the seat on there when I try again...
- Has thanked: 602 times
- Been thanked: 4529 times
You appear to have let one of your children doodle on your leg
It's looking the part now man.
Get a tow and see if it starts.
- derek badger
Put yer specs on you old git...notice something crucial missing from you plan?
Nidge
- Has thanked: 684 times
- Been thanked: 673 times
Big enough balls?derek badger wrote: Tue Feb 23, 2021 3:11 pmPut yer specs on you old git...notice something crucial missing from you plan?
It's still on a stand?derek badger wrote: Tue Feb 23, 2021 3:11 pmPut yer specs on you old git...notice something crucial missing from you plan?
- Been thanked: 2730 times
- G.P
- Has thanked: 1994 times
- Been thanked: 1283 times
Looks Ace Mr Badger. have you tried swapping the HT leads over? Its a common mistake. That and the cam timing.
If its not that, it could be that you've installed the wrong power band.
HTH.
HTH.
- Has thanked: 1059 times
- Been thanked: 1646 times
Naah, I reckon its the starter motors too old and knackered.G.P wrote: Tue Feb 23, 2021 7:53 pm Looks Ace Mr Badger. have you tried swapping the HT leads over? Its a common mistake. That and the cam timing.
HTH.
