Better sooner rather than later as most places will be busy just now now with similar jobs, it’s better having it ready to go when the time comes. With that being said the amount of times I’d get jobs at the last minute with people stating “I need it asap the grass is growing”Nordboy wrote: Wed Jan 14, 2026 1:04 pm Wull, quick question which I think I know the answer to.
When does the market kick in again? I have a Honda sit on lawnmower that needs a service and going over ready for the spring/ summer.
I'm guessing I should really get it booked in ASAP with a local company to sort out?
they'd have to pick it up, so what sort of price should I be looking at? I inherited this mower with the house when I moved and have no idea what I'm doing with it tbh.
Cost purely depends on the workshop hourly rate or whether they are doing any deals on servicing, x amount for a service etc, maybe free collection for winter service. I always worked purely on the hourly rate, but on a small ride on lawnmower it usually takes 1hr for a service inc lubricating cables,grease points and checking it over including belt and pulleys.
So you’ll have to factor in costs for oil, filters and plug(s). If the mower works as it should then you shouldn’t have to worry about anything over and above, the usual issues over and above are the belts and pulleys, you usually have transmission, deck and pto belts and this is what can easily drive up the cost of a service.
I forgot to mention cutting blades, sharpen and balance unless they are pretty gubbed then they’ll need replaced. It only take 15 minutes to remove them, sharpen and balance and refit so shouldn’t really make a big difference to cost unless they need replaced.
