Has thanked: 19491 times
It's virtually impossible to pack up an overfull 13sqm apartment whilst still needing to live in it!!!
Soooo - I've packed some stuff I will take straight to the new place, including the bedding so I can sleep there tomorrow! Then Imll have more options for using space here!
Bloody hoping that from Saturday I can use my mates garage again for storage cos an awful lot of stuff will need to go in 'a' garage!!
Has thanked: 711 times
Been thanked: 2014 times
Superglue. What cant they make a superglue resistant cap. That is another half a tube in the bin.
Has thanked: 781 times
Been thanked: 1068 times
Drain rods that unscrew themselves with the slightest little tap,
Narrow drain access chambers that have been buried much lower than they should be, resulting in drain rods that can't be constantly turned to stop them unscrewing.
Larger sewer chambers with outlets up close to the top under a cap so I can barely see it let alone get any tools in there.
Saga Lout
Has thanked: 596 times
Been thanked: 745 times
Post by Saga Lout »
The bin men* came today. I had to go out just after they emptied my bin and left it blocking my drive so I moved it onto the lawn intending to take it to the back garden when I got home. When I got home about an hour later, somebody had moved it back onto the drive so I had to get out and move it onto the lawn again before I could park. I don't understand why anybody would do that. There's some weird people around. :wtf:
* Sorry, of course I mean the refuse disposal operatives. ;)
Felix wrote: Thu Apr 24, 2025 7:58 pm Superglue. What cant they make a superglue resistant cap. That is another half a tube in the bin.
Cyanoacrylate is moisture curing, as soon as it's exposed to water it begins the sticky reaction. That's why it doesn't set in the tube....no moisture! Any residue on the outside will be exposed to atmospheric moisture, hence sticking your lid on.
HTH :thumbup:
Has thanked: 8007 times
Been thanked: 5665 times
Mr. Dazzle wrote: Fri Apr 25, 2025 8:01 am
HTH :thumbup:
And it's good at sticking fingers together because it was created to stick wounds together in a hurry on the battlefield. (Though this may or may not be apocryphal but it's what my physics master said when it first appeared for general use. Even then I think he ordered it from a scientific equipment supplies company).
I heard it was developed to stick optics together and the flesh thing was an accident.
More likely it was developed merely to be sticky and the applications came later!
Using the glue as a plaster is exactly my main usage. Bloody fingers are always getting crack in the sides what can be nippy as hell. When at work they get filled with dirt so i glue the cracks up. Nippy relief for the day :thumbup:
Mr. Dazzle wrote: Fri Apr 25, 2025 8:13 am I heard it was developed to stick optics together and the flesh thing was an accident.
It was accidentally developed by Eastman-Kodak apparently. They were trying to make a clear plastic and it was one of the failures. (See also Post-it notes for another accidental development :D ).
Slippery PTFE (Teflon) too, AFAIK. PTFE was developed as a lightweight alternative to rubber insulation for use in airborne electronics, something it's still used for a lot. The fact it's non-stick came much later.
Felix wrote: Fri Apr 25, 2025 8:36 am Using the glue as a plaster is exactly my main usage.
Gonna take ages to do an entire living room using little tubes.
Mr. Dazzle wrote: Fri Apr 25, 2025 8:55 am
Small bathroom. Been in this house about 17 years and got two walls done (Y)
Has thanked: 2272 times
Been thanked: 2654 times
It's fucking snowing...
Bigjawa
Has thanked: 225 times
Been thanked: 969 times
Post by Bigjawa »
Count Steer wrote: Fri Apr 25, 2025 8:07 am
HTH :thumbup:
I use it for sticking cuts closed. Great stuff
Count Steer wrote: Fri Apr 25, 2025 8:07 am And it's good at sticking fingers together because it was created to stick wounds together in a hurry on the battlefield. (Though this may or may not be apocryphal but it's what my physics master said when it first appeared for general use. Even then I think he ordered it from a scientific equipment supplies company).
Apparently first used in Vietnam War for exactly that. I had some MOD stuff that I was given by an RAF bloke that made the civilian stuff look like wallpaper paste.
Has thanked: 12556 times
ZRX61 wrote: Sun Apr 27, 2025 2:21 pm
When I worked at Lucas Aerospace in my youth, they had IS12 which was superceded by IS496 IIRC
Scary stuff.
Has thanked: 2317 times
Been thanked: 1821 times
Post by Jody »
' Internet' security...... again
My blood test results were sent to me. A secure document I needed a password for, enter the password, the document opens. Wonderful. (all on my phone)
It's required that I print the results and take them with me this afternoon.
NAH, can't print this document, it's secure, my phone tells me.
I'm advised to try my laptop, and sure enough, I open the same document using the same link and print it off with no issues.
How can it be considered "dangerous" to be able to print it from my phone but fine to print it from my laptop?
Has thanked: 7585 times
Been thanked: 5913 times
When bottled water costs over twice the price of pump petrol.
I usually take plenty of tap water, but needed to get more today :(
Sunny
Has thanked: 3530 times
Been thanked: 1663 times
Post by Sunny »
I take this back. ALLLLLL the way back 👍
Sunny wrote: Thu May 30, 2024 11:01 pm Anyway BYP: pet insurance.
Our lovely dog has just turned ten (ish - he's a rescue, so it's all a bit ish). He now costs more to insure than the fucking Audi.
Sunny wrote: Sun Jun 02, 2024 10:03 am > £1000 😭
£1043.35 to be precise. He's a big lump rescue mix from Croatia, so who knows what he is, but the vet reckons there's Irish Wolfhound and German Shepherd in there somewhere. I assume the turning 10 (ish!), has caused the bump up.
Has thanked: 1097 times
Been thanked: 5865 times
Went for a couple of beers last night, to a pub in East London. It's been taken over by an Irish pub group and was staffed by Irish guys. My colleague, who is half-French, half-Swedish was at the bar ordering a drink and struggling to understand as the barman had a thick Irish accent. I jokingly mentioned she was struggling due to the first-language thing, to which the guy made a comment to me about 'at least she's not English with 800 years of raping and pillaging history, eh?'
I laughed it off, but the more I think about it, the more I'm thinking it was a pretty offensive remark, not to mention stupid as when I recounted what was said this morning the consensus was that we wouldn't be going back again.
And their range of beer was pretty awful too.
It's not even like the French have a spotless record in that regard either! Go back and tell 'im.
