Exhaust stud replacing
- Felix
- Has thanked: 717 times
- Been thanked: 2045 times
- Has thanked: 2557 times
- Been thanked: 4168 times
Re: Exhaust stud replacing
I use copaslip (well, the Wurth version of it, CU800). Loctite is a waste of time as the temps at the exhaust port are enough to render it ineffective.
- Has thanked: 2295 times
- Been thanked: 2684 times
We don't use anything, just finger tight as torque is acquired when you tighten the nuts. Same deal with the 1/2in ARP head studs when I built my 460 CobraJet (which I think were 180ft/lb when torqued), ditto on aircraft engines.
- Has thanked: 20884 times
- Been thanked: 13703 times
As ZRX61 said finger tight and if you can, use brass nuts. as they cut off easily should you have problems down the line...
Bought a set of copper plated nuts a while ago for different bike. Didn't use them and happily they fit the triumph. Coppaslip and finger tight seems to be the way to go. Cheers.
