Car aircon, leaks and uv lights
Has thanked: 24 times
Been thanked: 358 times
Post by ..... »
Topped the gas up in the car over a month ago as it just wasn't cooling. Done about 1000 miles since the...... and back to square one again.
However, the stuff I put in had some uv dye additive, which I'm told requires a uv light to trace the leak (s)
Question is, will any old uv light work (cheapo amazon thingy) or does it need a proper jobbie?
C'mon cheapo😁😁😁
Has thanked: 781 times
Been thanked: 1072 times
Re: Car aircon, leaks and uv lights
Cheapy ones will be the right colour but maybe not as bright, buy cheap and do it at night.
Been thanked: 9503 times
On an semi-related note.
How did you top the gas up the first time?
If you did it via a trader they should have drained the system, then pressurised it and checked for leaks, before refilling it with the right gas.
If you topped it up yourself without wondering where all the old gas went, then maybe you need to have a think about that :)
I had mine done on a JCW Mini, it failed the test. They sent me away with a bottle of STP stop leak stuff. I'd followed the instructions and the next weekend went for a free re-test, it passed and they filled it with gas and it worked until I traded it a year later.
KungFooBob wrote: Sun Aug 10, 2025 8:11 pm On an semi-related note.
That ^
Gas doesn't just magically teleport away..... ;)
"Just needs a regas". Yeah. Because it's got leak :obscene-birdiedoublered:
Post by ..... »
And this is why I'm asking the question, because the dye will highlight where the leak is. If the condenser is fubar, I won't bother shoving more gas in there, if a seal is weeping, then a proprietary bodge or proper repair will be done prior to refilling
Has thanked: 2295 times
Been thanked: 2684 times
..... wrote: Sun Aug 10, 2025 10:24 pm And this is why I'm asking the question, because the dye will highlight where the leak is. If the condenser is fubar, I won't bother shoving more gas in there, if a seal is weeping, then a proprietary bodge or proper repair will be done prior to refilling
Old systems use flare fittings, modern stuff uses O rings.. so if it's O rings then fixing the leak is pennies. Not sure what the law is where you are, but here it's illegal to vent the gas to the atmosphere... but if there's bugger all in it you're good to go. You can pressurize the system with nitrogen while looking for leeks.
.. then there's the oil in the system
Post by ..... »
Internet says O rings
edulord
Been thanked: 9 times
Post by edulord »
Honestly, cheap UV lights can sometimes show the dye, but they’re usually not bright enough to spot small leaks. If it’s a tiny drip, you’ll probably need a proper one from a garage or a decent kit. For a quick check, the Amazon ones might give you a clue, but don’t expect it to be super precise.
Has thanked: 2557 times
Been thanked: 4168 times
ZRX61 wrote: Sat Aug 16, 2025 2:44 pm You can pressurize the system with nitrogen while looking for leeks.
You sure about that boyo?
