So i was fitting the Mavens .... That bit went fairly well, apart from some slightly questionable internal routing from Trek, which they didn't really resolve until the next generation.
20260525_095848 by
steveweeks59, on Flickr
Quick test and bedding in of the brakes and they're all happy. Although he had done a lovely fix there as he was running 203 rotors so used a caliper floating spacer to spacer it out to 203mm instead of spending £6 on a bracket... I'd do it as a quick fix to get me out on the trails, but that's about it in truth. So i fitted a SRAM 200mm on the front and that's now all good to go.
I was then looking at the shock and thinking "how's that actually mounted... with the simple answer being "really really fucking awfully"
The bloke had butchered sort of bolt things and spacers onto the bearings.
20260525_095146 by
So the spacers were squashing the bearing and all 4 were pretty mullered.
New set of 6800 bearings went in all 4
20260525_102529 by
Then fitted the standard shock.
20260525_105745 by
All 4 bolts are Trunnion style, which is a lot easier as there's no through bolt and the diameters are all correct. Whilst the coil felt nice this morning, i'd rather have it correct lol. I know from previous fitting that TFTuned have a mounting kit, so i may look into that for another day, but for now i'll run the air.
You can't really see it but he'd also fitted the knock-block headset completely wrongly, they're 'indexed' to stop things hitting where they shouldn't, but if you flip the spacers upside down they still go together but with spaces. WTF man.... seriously.
20260525_080334 by
So that's now all correct too.
