Those suspension mounting brackets are not standard...
The wideline frame doesn't have cupped shock mounts either :
Anyone got a lathe?
I’ve had a think and I don’t think there’s any reason the inlet rocker should weigh the same as the exhaust one, except that it’s a vaguely “good thing” for them both to be light and rigid.Buckaroo wrote: Mon Nov 03, 2025 12:19 pm I hope this isn't a daft question, but do they need to weigh the same amount?
I kind of had the opposite thing on my Wideline when I bought cheapo EMGO shocks, ordered by size not application: the brackets on the frame were too narrow for the eye of the shock.Rockburner wrote: Fri Nov 21, 2025 10:01 am]
The shock uppers have at least 1/2" of movement side-to-side!!
Very kind of you to say! Thank you.Supermofo wrote: Tue Nov 25, 2025 9:52 am Must say I love reading about your tinkerings with the JAPton, well written, entertaining and enlightening. I have no clue as to half of what you're doing but it's a bloody good read none the less and fully explained with pics. Top work.
All true, but in mitigation:JackyJoll wrote: Fri Dec 05, 2025 10:16 am The holes in the frame for the horn wire will let rain water into the frame tubing.
Frame earth return is good enough for the horn and kill switch, so long as the forks have continuity to the main frame through a wire (not just through the steering head bearings.
Lights, ignition and charging system need return leads for reliability. Relying just on frame and casing connections causes breakdowns, eventually.
The red and blue plastic pre-insulated crimped connectors aren’t as good as Jap type with a W crimp and separate insulating sleeves.
From memory, simply quenching most steel will embrittle it but doing it in oil might just add a tad of carbon to the surface? High carbon steel will quench harden though.iansoady wrote: Mon Dec 15, 2025 3:48 pm I'm not sure if quenching steel will case harden as such. I usually quench steel in old engine oil in an attempt to harden it, often setting myself on fire in the process......
