Phoenix wrote: Thu Feb 25, 2021 12:28 pm
Depends if you want to hide how the two surfaces are joined. Just do a search for metal joining strips. Screw in from the bottom making sure the screws are not too long that they go through to the top. You could also use a piece of plywood or similar to hold them both together if fastened from below.
You can buy cover strips in all colours and materials. Plenty for sale on EBay.
Examples
Good Luck
Awesome - I'll have a look in the places in the valley first but might end up hitting ebay!!
Mussels wrote: Thu Feb 25, 2021 12:45 pm
Joining strips are by far the easiest way, mitre joints aren't all that difficult but you need access to tools and space to use them. How picky are you about how it looks? If you are joining straight bits I'd just buy a new worktop the right length.
For exposed ends just buy end caps, remember to seal any cut edges with PVA or similar.
Really not picky at all - as you can see from the photos below!! LOL I managed to get a full length piece of work top (2.5m??) for about 15€ and it is a 'work in progress' to find out how to make the kitchen work best!!
DEADPOOL wrote: Thu Feb 25, 2021 1:00 pm
Much easier to buy a full size worktop and replace the existing half size one. Picture would help.
Probably didn't write the first post well. A full size work top is wider than my apartment!! And the 'kitchen' is in a corner. So things need to be cut and joined whatever I do!!
Silly Car wrote: Thu Feb 25, 2021 2:16 pm
While it possible to join two sections of worktop with minimal visible joint, you need some serious kit:
- Something to cut them with - track saw, router and guide rail or template, table saw with cross cut sled - eg not a jigsaw
Something to cut slots for worktop clamps - router (either freehand or with a template
Whilst not 100% necessary - something to help align the pieces - biscuit jointer, domino cutter, dowelling jig etc
Glue and patience
Jointing strips will do the job, but they are imho designed to cover the gap rather than support the joint, so you’d need to glue and screw in a suitable support piece to keep the joint stable.
As has been said, an entire new piece of worktop might be your best bet.
LOL I'll have to check, but pretty sure it was originally cut with a jigsaw - just not by me!! LOL And if that's the way we do it this time, I won't be cutting it in a curve, that's for sure!! LOL
The whole apartment has been one 'on the cheap' and with favours as, once I'd bought it, I was physically able to do the things I'd planned!! So whilst this needs to be workable, it also isn't likely to be needed more than a couple of years! (Hopefully) I have a chippy friend who is willing to come out and swap holidays for spending the time here to redo the woodwork currently in place (partitions and kitchen!).
But, the end result this time does need to be useable.
The new end won't be home to anything heavy tho, but I'll have to find out how to support it!!
Really rubbish pictures!!
Right now I'm just going to use an offcut from the original work surface, so will need a join where the FridgeFreezer is at the moment. Plan is to put the acquired fridge there instead and get much more work surface and also be able to use the sink better!!
It'll need a cover over the cut side (which will have to be curved to make sure I don't impale myself on it regularly!!) as well!
This end will need a 'cover' as that has been open since it was originally cut/built
Jody wrote: Thu Feb 25, 2021 1:52 pm
How long does the finished worktop need to be?
I have a mate that works at a kitchen place and he regularly gets worktops FOC. You'll have to wait until next december for delivery (along with your conditioner and tea bags
) but if you let me know what you need I'll see what I can sort out before I leave the UK !
I might well take you up on a new piece - simply because the bit around the sink wasn't sealed well and so won't last very long as water goes into it (might also give me a chance to change the sink to a more user friendly version!! Cheap isn't always cheerful!!)
It will need two pretty short pieces - the hole for the sink impacts on them both!!
