Yeah I saw those - I kinda wonder what happens to any bit of gasket which fall off in the PRT though! Why would they fall off I suppose.JackyJoll wrote: Sun Jun 27, 2021 9:32 pm You can make or buy a rocker cover gasket with individual pushrod holes, to align the pushrods with the rockers, as you fit the cover.
Yeah true - typically peak "BMEP", the average 'useful' press in an engine over the whole time it's running, is about 10 bar (probably a bit less in this bike). So if you just average the pressure in the cylinder over a long time including all intake, combustion etc. it's about 10 atmospheres. Or the pressure above the piston is about 10 times that below.JackyJoll wrote: Sun Jun 27, 2021 9:35 pmA damn site more than an order of magnitude during combustion.Mr Dazzle wrote:the pressure above the pistons is an order of magnitude higher than that below it
Peak pressure is more like 50-100 bar.
