Need to be concerned?
Re: Need to be concerned?
MrLongbeard wrote: Sun Jun 01, 2025 6:57 pm
ChrisW wrote: Sun Jun 01, 2025 6:26 pm
KungFooBob wrote: Sun Jun 01, 2025 6:18 pm You're missing the washer, rubber part and m8 nut.
Might still be inside the handlebar.
They will be they've no way of escaping, they should be on the other side of the collar he tapped back into the bar.
Best guess is the nut has gone walk about if he can't get it to engage the threaded bar on the indicator.
So the connector on the end of the indicator wiring has to be able to fit through the nut wand washer & I'm assuming the hole in the bars that it passes out of is too small to get anything in from that end, so you can't drag the nut etc. out with something attached to the indicator connector.
Connect a line to the indicator connector, pull it through then tip out whatever's left using gravity?
Has thanked: 1926 times
Been thanked: 1728 times
Take it to the dealer
Or just don't turn right.
Avoid MK.
Has thanked: 10971 times
Been thanked: 4004 times
Noggin wrote: Sun Jun 01, 2025 6:35 pm Someone must be close enough to go offer a hand ???
No one is brave enough to enter that pool of quicksand.
Docca
Has thanked: 731 times
Been thanked: 1437 times
Post by Docca »
I’ve put superglue on it. Fuck it
Has thanked: 8048 times
Been thanked: 5698 times
:eh:
Is the dealer 200 miles away or something?
Has thanked: 780 times
Been thanked: 3224 times
WTF
Docca
Post by Docca »
Count Steer wrote: Mon Jun 02, 2025 1:42 pm :eh:
Nearest dealership is an ex Harley place that by their own admission don’t know about Indians
Nearest all bike dealership is 15 miles away. Might as well be on the moon given work commitments for the next few weeks
Been thanked: 15511 times
Docca wrote: Mon Jun 02, 2025 2:41 pm
There's nothing 'Indian' about it mate, it's just a nut and bolt system, any mechanic could sort this in 2 minutes.
Been thanked: 14171 times
Docca wrote: Mon Jun 02, 2025 1:40 pm I’ve put superglue on it. Fuck it
Holy shit Doccs.
Is there not a handy old mate,or a tame spanner jockey close to you to at least have a look?
MyLittleStudPony
Has thanked: 835 times
Been thanked: 587 times
Post by MyLittleStudPony »
Graft life's hard! :(
The B-Town Grafter was explicitly clear on this point.
Been thanked: 9505 times
Run out of gaffatape?
