Need to be concerned?
Docca
Has thanked: 731 times
Been thanked: 1437 times
Post by Docca »
Just got back from a ride out. The right hand side of the handlebar near the mirror seems to have a gap. I have no idea if that gap has always been there - I suspect not.
I tried to push and pull stuff but nothing. Is it possible that there was a weight on their or something and it’s just fallen off?
Thanks as always
Been thanked: 9505 times
Re: Need to be concerned?
Banana for scale?
Is there a bolt/screw in the end of the handlebar?
KungFooBob wrote: Fri May 30, 2025 7:44 pm Banana for scale?
It's one awkward reflection, Michael, How much could it cost?
Has thanked: 5970 times
Been thanked: 3574 times
I'd be more concerned by the shirt!
MyLittleStudPony
Has thanked: 835 times
Been thanked: 587 times
Post by MyLittleStudPony »
I'm fairly sure it will need loosening somehow, pushing back in, then tightening back up.
Docca
Post by Docca »
So the bar end is an indicator.
Banana shirt is a shirt
derek badger
Has thanked: 1091 times
Been thanked: 1762 times
Post by derek badger »
Set fire to it
derek badger wrote: Fri May 30, 2025 8:11 pm Set fire to it
Jeez, don't suggest he set it on fire himself, you'll put me out of business.
Docca
Post by Docca »
For fucks sake you shits- any sensible suggestions before I go to Reddit? 🤣
Has thanked: 3022 times
Been thanked: 1750 times
Docca wrote: Fri May 30, 2025 8:31 pm For fucks sake you shits- any sensible suggestions before I go to Reddit? 🤣
It's already been mentioned. Undo the bolt in the end, push it back into the bar, tighten the bolt.
Has thanked: 1926 times
Been thanked: 1728 times
Pirahna wrote: Fri May 30, 2025 8:35 pm
That would strike me as the sensible suggestion - you will need the right sized Allen key.
Whether you do that , or burn the shirt first, is you decision 😉
Have you tried hammering it back in with the sole of your shoe?
derek badger
It's vibrated loose. Undo the Allen bolt, push it home and tighten it up again princess.
derek badger
KungFooBob wrote: Fri May 30, 2025 8:52 pm Have you tried hammering it back in with the sole of your shoe?
High heel or UGG boot?
derek badger wrote: Fri May 30, 2025 8:54 pm
Birkenstock , I would guess
Docca
Post by Docca »
derek badger wrote: Fri May 30, 2025 8:53 pm It's vibrated loose. Undo the Allen bolt, push it home and tighten it up again princess.
What Allen bolt?
I have uggs 😀
Docca wrote: Fri May 30, 2025 9:13 pmI have uggs
Disaster averted.
Has thanked: 780 times
Been thanked: 3224 times
What Allen bolt?
I have uggs 😀
Should've bought a Harley :obscene-birdiedoublered:
Guessing they're Motogadget jobbies, in which case no Allen screw, just unscrew the indictor, could be tricky depending on how long they've been on there / seized up
Oh and do remember to hold the exposed shaft, don't come crying to us because you've forgotten and twisted the wiring to buggery, best bet is to get a man in.
derek badger
You said "exposed shaft", Docca is currently laughing...
