Where to buy specific bolts?
Has thanked: 10971 times
Been thanked: 4002 times
Anyone know a good source of bolts where I can search specific attributes like the length of the shank (unthreaded length).
So far I've found lots of sources but none that give a great deal of detail about what you're buying.
Been thanked: 4529 times
Re: Where to buy specific bolts?
No, which I appreciate isn't helpful, but I've looked for the same thing, but everyone seems to stock the same bolts these days.
Trinity765
Has thanked: 3145 times
Been thanked: 3188 times
Post by Trinity765 »
iansoady
Has thanked: 72 times
Been thanked: 244 times
Post by iansoady »
Here: https://www.fusionfixings.co.uk/
Good prices, huge range.
Been thanked: 9503 times
Do you have a branch of BAPP nearby?
https://www.bapp.co.uk/
Been thanked: 14171 times
Thanks for the replies everyone.
TBH, I'm looking for a 1/4" BSC (Cycle)* threaded bolt, 1 1/4" length with the shank length of around 7/8" (the shank length is the important bit). If necessary I'm happy to cut down the threaded portion of a longer bolt. (none of the suppliers above seem to stock BSC/Cycle - not really a surprise, I know it's an antiquated threadform)
For reference - I need a couple of these for the smaller engine case bolts that hold the JAP engine cases together. For some reason the 2 bolts I have are "set-screws" (threaded the full length), which means that the cases aren't held in proper alignment if those are the only 2 bolts in place (eg when installing the motor into the engine plates).
I think I've found a source (Speedway spares do seem to sell one, see "Chances clamping bolt front and rear" here : https://www.speedwayserviceltd.co.uk/jap-parts-2 , I need to confirm their pricing), but was hoping to find a supplier for long-term sourcing. :)
* Because that's what's there and I'm "trying" to balance original with useable/findable at the moment: If I need to use BSF I'll do that, but definitely avoiding metric where possible (for originality)
iansoady
Post by iansoady »
I didn't realise you wanted Cycle threads. Try Middleton (https://www.stainlessmiddleton.co.uk/32 ... -setscrews) who like Nooky's supply 1/4" BSF as Cycle. Good enough but not for the purist. He has a 1/4 BSF x 1.1/14 listed. Molnar is another possibility: https://www.manx.co.uk/products/stainless.html
I usually make studs in the lathe to replace bolts as I can ensure the thread length etc is exactly what I want.
kendo57
Has thanked: 399 times
Been thanked: 748 times
Post by kendo57 »
https://www.classicbikepartscheshire.co ... aded-p4902 You can buy a Die and cut the threads of these further down
iansoady wrote: Thu Nov 20, 2025 2:15 pm I didn't realise you wanted Cycle threads. Try Middleton (https://www.stainlessmiddleton.co.uk/32 ... -setscrews) who like Nooky's supply 1/4" BSF as Cycle. Good enough but not for the purist. He has a 1/4 BSF x 1.1/14 listed. Molnar is another possibility: https://www.manx.co.uk/products/stainless.html
The problem I have is that the online information never tells you how long the shank is, and I'd rather not order 50 frigging different bolts just to find the "one" that has a long enough shank.
I may well be reduced to buying the longest things I can find and spinning the die down 'em. (at least I have a die now! :D)
kendo57 wrote: Thu Nov 20, 2025 2:22 pm https://www.classicbikepartscheshire.co ... aded-p4902 You can buy a Die and cut the threads of these further down
Yup
(incidentally - how the hell did you find these???)
