Shadow foam toolbox/case
Has thanked: 10971 times
Been thanked: 4004 times
Re: Shadow foam toolbox/case
MrLongbeard wrote: Tue Nov 05, 2024 11:58 am A dymo label printer should be cheap enough on ebay
A set of paint pens even cheaper.
(I have both, the dymo doesn't get a lot of use since I bought the paint pens....)
Has thanked: 780 times
Been thanked: 3224 times
If I had to label my tools, and if I didn't have the shakiest hands in all of Christendom, then, https://www.ebay.co.uk/itm/355051747531 ... R6rYmMnfZA
Been thanked: 15510 times
So we're back to the start of the season and back to 'what now' for the toolbox stuff.
Since fitting the corner brackets it's been pretty solid i have to admit, although counter to that, i don't exactly love it lol. But it's good enough for sure.
The layout though taught me there's loads of things i have in there i want and loads i don't... along with that, some of them are in the wrong places and layers... so i've got a few things to move, change, swap.
ImageIMG_20250409_163327 by Steve Weeks, on Flickr
This is the latest version that i'm thinking/hoping will do me for 2025.
Has thanked: 1059 times
Been thanked: 1646 times
weeksy wrote: Wed Apr 09, 2025 4:45 pm some of them are in the wrong places and layers... so i've got a few things to move, change, swap.
Thats a constant battle for me, powertools in the van are pretty much constant but the handtools I need change from job to job and as soon as I put an infrequently used item like Glass Suckers away in the bottom tool box I get a job that needs em.
You're only going to need one cable tie for the whole year? Impressive.
Has thanked: 12620 times
Been thanked: 8541 times
Get a decent sized board and layout all your tools and draw round them. Add nails screws to hold them in place.
Chuck everything into a big box.
At each race meeting spend 5 mins putting each tool in place.
Then you have everything you might need all weekend in handy, easy reach place.
Has thanked: 19612 times
Been thanked: 4960 times
Yorick wrote: Thu Apr 10, 2025 11:30 am Get a decent sized board and layout all your tools and draw round them. Add nails screws to hold them in place.
You haven't seen the Weeksy tools IRL ???
You'd have written all that and then deleted it, not posted it !!!
:lol: :lol: :lol:
like this he means :)
weeksy wrote: Fri Apr 11, 2025 7:07 am like this he means :)
That makes more sense!!! I was picturing spare plywood and screws being suggested :angelic-green: :lol: :lol: :lol:
Got a hard plastic case today that's much better for the job. It's slightly bigger so a bit more space in there too.
Only downside is that the lid doesn't 'stop' around vertical, so i may need to employ the brackets i had from the old one for the job, either that i when it's open it's fully open. Not sure yet. It does have 'stops' in the moulding which means it doesn't go completely past flat, so i could modify that to stop just past vertical.... Not sure yet what will be the perfect plan.
ImageIMG-20250417-WA0001 by Steve Weeks, on Flickr
First layup of the tools to go in...
Next debate is whether i used Red Box Tools and have all the items precision scanned/cut into their foam or whether i use some shadowfoam i have for the job... Setup and cutting out is about £125 including the foam.
draft 2
ImageIMG_20250417_135322 by Steve Weeks, on Flickr
Tricky
Has thanked: 3045 times
Been thanked: 3309 times
Post by Tricky »
I find this thread quite cool, and also quite disturbing in equal measure 😁
Either way, it keeps me coming back! :thumbup:
Has thanked: 8048 times
Been thanked: 5698 times
Tricky wrote: Thu Apr 17, 2025 5:57 pm I find this thread quite cool, and also quite disturbing in equal measure 😁
It's the quest for the perfect solution to a problem most of us decided had no perfect solution many years ago. :(
I tried to rationalise my tools into categories like 'plumbing', 'electrical', 'mechanical' so many times before realising that only a % are specific the rest cross categories so either you end up going 'Which lot are the big pliers in?' or buying a pair of big pliers for each lot. :lol:
At least this is focused on one task - keeping a bicycle going - so I watch in hope that someone finally nails it. :thumbup:
Count Steer wrote: Thu Apr 17, 2025 7:11 pm
If he was really dedicated he'd change bits on the bike to reduce the number of tools needed ;)
Mercedes F1 (and presumably others, Merc is the only one I have direct knowledge of) make some custom fasteners for that very reason.
crust
Has thanked: 964 times
Been thanked: 713 times
Post by crust »
Mr. Dazzle wrote: Fri Apr 18, 2025 3:24 pm
Competition enduro bikes are built that way as they have to be fixable on the course or in a ten minute window at the end of the day. Honda XR models used to come a couple of tools that fitted all the bolts.
Modern KTM enduros are the same.
crust wrote: Fri Apr 18, 2025 4:55 pm
Yup. Same on my GasGas :)
Getting there. May need a few tiny little trims to make sure things are secure. But it's pretty damn close.
ImageIMG_20250419_211351 by steveweeks59, on Flickr
Should there not be a little pot for left over washers nuts and things that dont fit anywhere?
STANDS BACK......
David wrote: Sun Apr 20, 2025 8:57 am Should there not be a little pot for left over washers nuts and things that dont fit anywhere?
STANDS BACK......
It's not a 1970s Brit Norton.
crust
Post by crust »
STANDS BACK......
The amount of spares he carries, he might as well put a handle on the roof of the van.
